New xj8 owner
Old Jun 4, 2018 | 12:33 PM
zagamuffin's Avatar
Default New xj8 owner
well lads,
I have just collected a new project, got myself a 2001 Original Irish 4.0 Xj8 , no salt on the road here up to a few years ago and even then not widespread so less rust than normal.Its relatively low ,ill millege at 101k and in ok condition.I will be going over the paintwork and interior plus a few suspension Bush’s but first the dreaded fault codes.
It has an eml and a gearbox fault which is prob A drum related.can get reverse but forward gears need @ 2k revs to engage and sometimes with a clunk.Codes are below but I haven’t had a chance to decipher yet.
P1722
P1647
P1000
Old Jun 4, 2018 | 01:46 PM
avern1's Avatar
DTC P1722 indicates gearbox default to 5th gear. Without reverse you are probably correct on the A drum failure. At any rate probably looking for a trip to a good transmission shop.
DTC P1647 indicates a defect in the upper oxygen sensor on B-Bank. That would be the upstream sensor on the left side of the engine before the catalytic convertor.
P1000 merely indicates all monitors are not set satisfactorily and when change to P1111 when the other DTC's are fixed.
Old Jun 4, 2018 | 02:05 PM
zagamuffin's Avatar
thanks Avern
p1722 is also flagged as failure of output speed sensor or transmission failure , what’s the chance it’s a sensor ( first time ever ???) , also seller said he power washed Eng bay which caused the fault codes which I took with a pinch of salt , but I wonder ???
Old Jun 4, 2018 | 03:32 PM
Lady Penelope's Avatar
If it is a speed sensor failure you can read through both input and output shaft sensors ( 2 ) 4 pins at the transmission ECU as they should read the same resistance as a fundamental test as they function as a pulsed wave to count the revs .'
You would have to read them after they warm up as this is a mode of the windings heating up and opening up the wire .
There are also reports of the on transmission itself connector getting contaminated from fluids from above . The connector is a push / pull type of connector like a air hose I believe .
Transmission pressure regulator change to the upgraded one recommended before " A " drum mechanical breakage .
See page 63 keeping in mind the SC engine uses a different MB transmission
http://www.jagrepair.com/images/Auto.../jagxj2001.pdf
Old Jun 4, 2018 | 05:38 PM
avern1's Avatar
Been there done that. Reverse only and no forward gears and slight movement at high revs is A drum. The XJ8 has the BMW trans. If you are handy you can do an advance search and find details for swapping out the A drum. If you want to try it yourself let me know I have the workshop manual for the transmission.
Old Jun 5, 2018 | 12:26 PM
zagamuffin's Avatar
might take you up on the d/l , forgot to mention i drove it home 300 miles and it was faultless A drum issue or not lol
Old Jun 19, 2018 | 01:02 PM
zagamuffin's Avatar
Hey,
i dropped the trans sump to investigate and had a spare new filter and oil ready for the best but got what I suspected. Lots of fillings and several chunks of metal in the sump.
Ah well, box out time ...
Old Jun 19, 2018 | 01:16 PM
zagamuffin's Avatar
tn98XJ8
Nov 5, 2013 10:38 PM
slmskrs
Jun 20, 2013 05:15 PM
lenalittle
17
Jan 17, 2012 07:18 AM
mik15
Feb 20, 2011 11:37 AM
chiliv6
Jan 7, 2011 05:31 AM
