Nice Auto-Scape article on 98-03 XJR
Old Jan 14, 2014 | 11:34 PM
jimlombardi's Avatar
Default Nice Auto-Scape article on 98-03 XJR
Here is the article Title and first sentence in the Auto-Scape.com article on 98-03 XJR:
1998-2003 Jaguar X308 XJ8(R)- An under rated scorching luxury Saloon
The Jaguar X308 XJR is a fabulous under rated machine and should go down in automotive history as a thoroughbred.
Also has a paragraph on Dissapointments and what would we have done better?
relatively cheap to make modifications to the XJR powertrain to get a lot more power. The supercharger is only driven at 2:1 drive ratio and the peak engine revs are 6150 rpm (the naturally aspirated engine revs to 6800 rpm). Eaton says the M112 has a peak rotational speed of 14000 rpm- which means there is some room to increase pulley ratios for more power if you’re willing to change the supercharger drive belt more often.
Here is the webpage link to the complete article:
1998-2003 Jaguar X308 XJ8(R)- An under rated scorching luxury Saloon | Auto-Scape
Jim Lombardi
Old Jan 15, 2014 | 06:21 PM
D. Fite's Avatar
Interesting read. Glad you put it on.
Dave
dsnyder586
Dec 29, 2024 07:39 PM
peterg19
Feb 10, 2023 09:02 PM
hunter34
19
Sep 14, 2022 11:09 PM
Steve10
Sep 14, 2015 07:40 PM
jmfan
Sep 12, 2015 10:28 PM
