no data link connection
Old May 17, 2016 | 03:05 PM
jaguar jon02's Avatar
Question no data link connection
got a 2000 xj8 ,that had a bad fuel pump, replaced pump nothing, turns over, but no spark or fuel pump action. hooked up my scanner and the adl want talk to it. all i get is error. jump pump relay and have good pressure. acts like no ground on relay to turn it on. have key power and batt power
Old May 17, 2016 | 08:17 PM
Highhorse's Avatar
How much battery power?....if its low, it may not link. Put a charger on it and try again....be sure to check your fuses also.
Old May 18, 2016 | 06:06 AM
new battery. found a pin broken on compter plug in. put one in from running car same thing . can't program or anything unless adl works ,hate to scrap it with only 67 k on the clock, but only have 600 in it
Old May 18, 2016 | 06:49 PM
Highhorse's Avatar
Have you tried referencing through this....JagRepair.com - Jaguar Repair Information Resource
Old May 19, 2016 | 08:17 AM
nothing in jagrepair.com to help. going to scrap out as i need money now , just bought a bentley/rolls
Old May 20, 2016 | 03:55 AM
Addicted2boost's Avatar
I know this is probably pointless and/or too late but, there's a fuse for the ALDL.
Old May 21, 2016 | 09:26 AM
i've checked all fuses in the boxes. which one is it and i'll recheck
Old May 21, 2016 | 07:11 PM
Highhorse's Avatar
Grounding may be the issue also, here's your ground points:
This is from a '98, but will be the same for you:
H20boy
Apr 23, 2016 11:40 AM
kreyszig
Apr 13, 2016 03:31 AM
tigger
Apr 2, 2016 08:56 PM
Michael Wittmann
Mar 29, 2016 05:16 PM
Michael Wittmann
Mar 27, 2016 07:45 PM
