NO heat 2000 xj8
the 10 amp fuse number 3 in the engine fuse box is okay. That is what I was told was the proper fuse, is that right. All of the fuses appear to be okay. Where is the pump relay?
I just checked my XK8 manual and do not see one, so you most likely do not have one either.
So the next thing I would do is check with a meter and see if you have power to the fuse.
