NO heat 2000 xj8
Old Nov 30, 2014 | 02:19 PM
tilbury's Avatar
Default NO heat 2000 xj8
I have no heat in my jag. The aux pump works but there is no electricity getting to it from the wire harness. What can I check next?
Old Nov 30, 2014 | 03:09 PM
RJ237's Avatar
Fuse and also relay, I believe. Do you have a wiring diagram?
Old Nov 30, 2014 | 05:12 PM
tilbury's Avatar
the 10 amp fuse number 3 in the engine fuse box is okay. That is what I was told was the proper fuse, is that right. All of the fuses appear to be okay. Where is the pump relay?
Old Nov 30, 2014 | 07:17 PM
RJ237's Avatar
I just checked my XK8 manual and do not see one, so you most likely do not have one either.
So the next thing I would do is check with a meter and see if you have power to the fuse.
Bcrary3
Sep 12, 2021 05:41 AM
corysansburn
Sep 10, 2015 06:15 AM
AtholC
Sep 9, 2015 09:07 PM
Super Cat
Sep 9, 2015 03:24 PM
stype40
Sep 9, 2015 08:14 AM
