O2 sensor and Cylinder Misfire
Old Nov 11, 2021 | 06:56 AM
asjdhsajhdfj's Avatar
Default O2 sensor and Cylinder Misfire
Hi, all.
Just posting to get an alternative viewpoint on this.
I’ve got the error codes:
P0420 - Efficiency Below Threshold
P0301-8 - Cylinder Misfire.
My plan is to replace to o2 sensor (if I can, am yet to research) and if the issue is still there then I’ll replace the ignition coils.
Old Nov 11, 2021 | 08:43 AM
RJ237's Avatar
I think you have it backwards. Replace the coil, do a hard reset and both codes should go away. But do some research on coils, there are a lot of poor quality ones out there.
Old Nov 11, 2021 | 08:48 AM
The O2 sensor message only comes up when driving on the motorway. The first time, it was the only code.
Only recently both codes came up.
My thinking is to replace the sensor as it's the cheaper fix, and if that does not fix the problem then change the coils?
Old Nov 11, 2021 | 11:51 AM
Jhartz's Avatar
So: misfire codes for all 8 cylinders, ne? have the secondary tensioners been replaced? Pull a cam cover and check for oil in the spark plug hole . . .
Lavitz
Jun 24, 2021 05:16 PM
Magdy Tawfik
Feb 13, 2021 02:23 AM
Jag in Aust
Jan 24, 2020 07:57 PM
radiatn
Dec 31, 2015 09:13 PM
lmerritt
Mar 4, 2014 02:37 AM
