Oh no! Boot open in red
Old May 12, 2015 | 12:53 PM
Morpheus311's Avatar
Default Oh no! Boot open in red
Gone a few months now without an eye catching message on my dash. It's been so nice. This morning was such a downer. I almost pulled jag back in garage and went to bed.
Old May 12, 2015 | 03:23 PM
CharlzO's Avatar
Accidentally hit the release somewhere? or perhaps a bad trunk switch?
Old May 12, 2015 | 04:07 PM
Boot is the trunk?
Old May 12, 2015 | 06:57 PM
CharlzO's Avatar
yes, in Brit speak, the Boot is the trunk (and Bonnet would be the hood, just for sake of argument there).
Old May 12, 2015 | 07:12 PM
Vector's Avatar
Originally Posted by Morpheus311
Boot is the trunk?
This should help:
British Car Terminology
Vector
Old May 12, 2015 | 08:33 PM
ericjansen's Avatar
Rather easily, you can take the trunk switch out from the lock assembly.
The actual switch is hold into a plastic housing (easy to separate), which also contains the latch assembly (the moving pin, which operates the switch).
With some luck, something is stuck or bent there.
I did mine just yesterday, as I had the reverse problem (switch did not always connect, hence the lights did not always go on).
Although the switch is sealed, I managed to spray some cab. cleaner into it, probable solving the bad contact.
Works better then ever before, at least for now.
I have a pic if needed.
Old May 12, 2015 | 10:46 PM
LOL! the boot was not all the way closed, the mains leads were not connected, the tea and crumpets were not available...
Thanks! I shut the trunk and all is well with the green money pit.
Old May 13, 2015 | 09:25 AM
CharlzO's Avatar
Glad to hear it I hit my release accidentally the other day, and didn't realize it until I went to lock the doors and instead of "chirp" it went "BEEEEEEEEEP!!!!" I was like, woah, that's different... wtf.. didn't see a door open, got back in the car, saw the message and went "oh, oops?"
On to better days!
Old May 13, 2015 | 09:33 AM
Jhartz's Avatar
On my first XJ8, I would consistently get the Boot Open message: after six tries -- it was under warranty -- the dealer's tech finally found a frayed wire in the the loom along the hinge.
I get it almost as frequently in the new one -- with arthritis in both knees, I am gripping the door, with fob between thumb and door, as I lower myself into the Jag, accidentally hitting trunk release . . .
Old May 13, 2015 | 10:34 AM
Catenaccio's Avatar
That was easy to solve. Next!
dsnyder586
Dec 29, 2024 07:39 PM
H20boy
Dec 24, 2024 03:23 PM
99xk8guy
May 28, 2024 09:36 PM
ym37tech
Feb 8, 2016 01:04 PM
SCMike
Sep 22, 2015 07:34 PM
