Oil in Air Intake
Old Jul 26, 2017 | 08:17 PM
jcvegasdog's Avatar
Default Housing from throttle body to maf
98 xj8: Removed housing, oil coming from breather hose on valve cover. Inside housing found oil up to throttle body. IS THIS NORMAL? Any filter on the breather hose?
Old Jul 27, 2017 | 12:58 AM
jcvegasdog's Avatar
Default Oil in Air Intake
98 XJ8: Cleaning throttle body & maf, found oil in housing between them, is this normal? Hose from valve cover to housing, is a filter used in hose? Also cleaned oil in housing, was this a mistake?
Old Jul 27, 2017 | 06:30 AM
Daim's Avatar
Totally normal. It is the crank case ventilation system and the oil condenses there...
Old Jul 27, 2017 | 07:52 AM
xjr2014_de's Avatar
+1 on what Daim sais.
As long as you don't have oil puddles in the intake system, you're fine.
If you're concerned then clean the intake + TB, drive a few weeks and if you have puddles again, then there's sth wrong.
But an oily layer in the intake is quite normal.
Old Jul 27, 2017 | 10:04 AM
motorcarman's Avatar
Here it is again!!
bob
Old Jul 27, 2017 | 08:18 PM
omgimali's Avatar
If I clean this engine breather will it "restore" lost power.
