Oil pan removal
Old Jun 21, 2009 | 04:21 PM
Dan R's Avatar
Default Oil pan removal
Thanks to this forum I will be tackling the replacement of the secondary tensioners with a lot more confidence.
I notice people take off the oil pan and fish for tensioner bits. How easy is this to do? What else should I be looking for once the pan is off. Can I clean the oil pick-up screen?
Thanks,
Dan
Old Jun 21, 2009 | 07:58 PM
sparkenzap's Avatar
Dan:
I don't think I'd fish unless I found some big chunks missing. If you decide to go there, I'ts pretty simple, just lots of little bolts. and yep, there is a screen. As I remember, no gaslet, just sealer.
Ross
Old Jun 21, 2009 | 10:11 PM
Dan R's Avatar
Thanks Ross,
I think I may let sleeping dogs lie. From the valve covers off recently to fix leaks I know that only one tensioner (red, 2nd gen.?) has a relatively small crack. I'll still do the tensioners for PM.
Old Jun 22, 2009 | 03:23 PM
sparkenzap's Avatar
Dan:
Thats why the screen is there, plus you have a filter after the pump.
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
tomsjag
Jun 10, 2023 10:02 AM
kstevusa
Sep 7, 2015 01:12 PM
Dymaxxion
Sep 4, 2015 02:40 PM
