Oil on spark plug treads
Old Mar 15, 2014 | 10:19 AM
firenfix's Avatar
Default Oil on spark plug treads
I pulled plugs out of 6 and 7 and found oil on the threads, none in the spark plug well? Car runs OK, no smoke. Any ideas, hopefully nothing major...
Old Mar 15, 2014 | 10:25 AM
sparkenzap's Avatar
Maybe a drip of oil in the well before removing them??? Don't seweat the small stuff!
Old Mar 15, 2014 | 10:42 AM
firenfix's Avatar
Seems like the entire thread surface had oil on it, does that seem normal?
I'm getting ready to pull a few more......
Old Mar 15, 2014 | 11:20 AM
Don B's Avatar
Oil seeping past the cam cover ("valve" cover) gasket can be drawn down the spark plug threads by capillary action. Perhaps your gasket isn't leaking at a sufficient rate to leave a pool of oil in the plug well? You might pull a plug from the other bank for comparison.
Cheers,
Don
Old Mar 15, 2014 | 12:22 PM
firenfix's Avatar
Default Oil on plugs
Thanks guys, pulled the other 6 and the oil is in the plug wells. Seems as I pulled them out they were passing through the standing oil causing the appearance of oil on the threads. Putting in new plugs for now and ordered a new gasket set with the o-rings
Thanks again!
Old Mar 15, 2014 | 01:20 PM
bigcat777's Avatar
While you have those cam covers off, you might take a look at your secondary tensioners, plastic or metal.
Old Mar 15, 2014 | 09:11 PM
firenfix's Avatar
I am planning on upgrading while I'm in there....
Old Mar 15, 2014 | 11:05 PM
xjay8's Avatar
Thanks again!
Common enough problem as the miles stack up ;o)
Engine oil seepage from the cam cover spark plug well seals.
When cleaning up the whole area,use carb cleaner and spray down into plug well....with plugs out and either blow dry with air or, wipe excess out with cloth on a wooden dowel.
When replacing plugs, add a dap of nickel anti-seize on the lower half of the plug threads for 180 deg. with a small paint brush and torque to 20lbs/ft.
You are going to replace cam cover seals anyway so, make sure mounting surfaces are clean and dry.
Spray carb cleaner on mounting surfaces....DO NOT use any sealant!
These are a 'compression' type seals....making sue they sit properly in the grooves in the cam covers.
you can hold them in place with a small dab of pet. jelly.
The only place a small dap of sealnt is used is over the joint between front of cylinder head and timing cover...a bead about 3mmx12mm is all.
Don't overtighten the cam cover screws!....8nm.
Work in criss-cross patern starting from centre screws.
While you have cam covers off, it pays to check and clean the breather
baffles in both covers...these are often over looked.
cissdm
May 3, 2016 06:02 AM
Shaggy9212
XJ40 ( XJ81 )
Sep 14, 2015 08:08 PM
Pristine97XK8Convertible
Sep 10, 2015 09:24 AM
mrplow58
Sep 9, 2015 11:27 AM
Bowman
Sep 3, 2015 03:17 PM
