old topic on differential oil change
Old Dec 16, 2019 | 01:17 PM
vincent661983's Avatar
Default old topic on differential oil change
please excuse my laziness, I know it is nothing new but planning to do the differential oil change on my 2000 XJR,
can any one tell me Exactly what oil I would need, how much (by volume) I would need. if I need any extract parts for the good maintenance?
also I/my mechanic need any special instruction manual
thank you
Old Dec 16, 2019 | 05:17 PM
Carnival Kid's Avatar
This forum thread has some info..........
https://www.jaguarforums.com/forum/x...ck-end-225373/
I see mention of Mobile 1 synthetic 75w-90 or 75w-140 with 4 oz of Molyslip.
Old Dec 17, 2019 | 07:50 AM
dwgates's Avatar
You may want to take the opportunity to clean the breather on the diff while you're in the neighborhood.
My axle seals were weeping but after soaking the breather in solvent and blowing it dry they seem to have stopped.
I read about someone else here on the forum who found the same thing...
Old Dec 17, 2019 | 09:28 AM
Samilcar's Avatar
1.9 quarts approximately. It's a little harder to find, but I use Mobil Delvac 1 75w-90. It's designed for open differentials only (no limited slip additives) and is slightly thicker than Mobil 1 LS 75w-90.
ronmexico
Dec 6, 2017 05:01 PM
racerx82
Mar 23, 2012 09:39 AM
JagLovr
25
Jan 9, 2012 06:35 PM
croppy
Feb 1, 2011 05:36 PM
McJaguar
Sep 25, 2008 11:00 PM
