Overhead console piece.
Old 01-10-2018, 02:46 PM
King Charles's Avatar
Received 1,019 Likes on 740 Posts
Default Overhead console piece.
Removing my overhead console for LEDs now I can't re-install it. The end towards the windshield fits fine into it's tangs but the (front/eyeglass holder) dangles. Looking @ the diagram it looks like a locking nut or nodule was there but mine never was, nor has it fallen during the install.
It was held securely before I removed it so what can I do to have it back secure without the piece. Also where can I find the part or # for it pictured below.
Never had so many issues replacing light bulbs, from brittle plastics disintegrating upon touch, to temperamental holders/sockets lol.
Edit :
I need # 5 from the diagram below.
Looks to be Part #: BBC7531PA
Old 01-10-2018, 05:37 PM
nilanium's Avatar
That is the correct part in your second diagram, it's a black plastic "screw" with 2 flats along the threads so you can push it in then turn it 1/4 CW to "lock" the console in place.
Agreed on the issues with working on those, such a pain to swap out bulbs, I crushed a bulb trying to pull it out of those insanely tight holders (mostly my fault but...) while trying to not break the plastic housing itself. Trying to R/I LED bulbs fought me even more. All the foam isolation stuff was also disintegrating into a sticky gooey mess that got everywhere.
King Charles (01-10-2018)
Old 01-10-2018, 05:48 PM
Indeed, I even have one of the console's map lights that refuses to illuminate a LED bulb, but works fine w/ the old OEM bulb ?! Not sure what that's all about lol.
Old 01-10-2018, 07:06 PM
Lyndon1116's Avatar
Default Similar problem
King Charles
I'd like to know how part 9 (in the 2nd diagram) gets held in, and couldn't get any sensible answers from SNG B about it. Mine had fallen off, and was previously only glued in by the looks of it.....
For now I have just used double sided tape to make it stay there, but the proper information would be good to know.
Lyndon
Way Down Under
Old 01-10-2018, 07:27 PM
Originally Posted by Lyndon1116
King Charles
Lyndon
Way Down Under
I'll have a closer look soon & post my findings.
Old 01-11-2018, 03:09 PM
harvest14's Avatar
If you just need that 1/4 turn plastic locking “screw” that goes inside the glasses holder, I have an extra one.
King Charles (01-11-2018)
Old 01-11-2018, 03:18 PM
Yes that's all I need, I found one on E-Bay but the seller's non-responsive. I'll give them until this evening which will be 24 hours, if no reply, I'll take you up on yours, thanks !
Old 01-11-2018, 03:25 PM
Sean B's Avatar
Received 1,341 Likes on 1,057 Posts
if you think that's bad, try trimming one
Attached Thumbnails Overhead console piece.-dscf4111-small-.jpg   Overhead console piece.-dscf4112-small-.jpg
ericjansen (01-11-2018)
Old 01-11-2018, 03:54 PM
What puzzles me is that it was secured without the stud previously, now I can't get that ?!
Edit :
I ordered the wrong part in BBC7531PA I need part # AGU2229LEG .
Harvest, I PM'd you sir.
Old 01-11-2018, 07:20 PM
harvest14's Avatar
I will be home in about an hour. I will post a picture of it and if that’s the part you need I will drop it in the mail tomorrow.
Old 01-11-2018, 08:27 PM
harvest14's Avatar
Default Console locking screw
I checked and this one is identical to the one holding up the ceiling console in my car.
Attached Thumbnails Overhead console piece.-img_4442.jpg   Overhead console piece.-img_4443.jpg
Old 01-11-2018, 08:34 PM
That's it sir ! Tell me what you need for it via PM , thanks !
Old 01-11-2018, 08:40 PM
harvest14's Avatar
Just PM me your address. An item this small is a community courtesy, lol. I'm sure you'll pay it forward.
The following 2 users liked this post by harvest14:
ericjansen (01-11-2018), King Charles (01-11-2018)
Old 01-11-2018, 08:44 PM
Sent.
Thanks !
Old 01-11-2018, 10:38 PM
ericjansen's Avatar
Received 1,351 Likes on 926 Posts
Is this forum great, or not?
The following 2 users liked this post by ericjansen:
harvest14 (01-12-2018), King Charles (01-11-2018)
Old 01-11-2018, 10:43 PM
Indeed if I'd discovered it sooner I wouldn't be on X308 #3 lol. All the issues I gave up on my 1st one for, are easily remedied by reading threads or asking here lol.
Old 01-12-2018, 11:19 AM
harvest14's Avatar
Shipped. PMed the tracking number.
With regard to this forum, I have certainly received more than I've given.
staffsbull (02-28-2019)
Old 01-12-2018, 12:54 PM
Forcedair1's Avatar
Same here, absolutely.
What did people do before forums and internet? Not only for its availability, but also for the number of sources that respond to you with their own experiences, and in such quick fashion.
Cheers,
Old 01-16-2018, 04:22 PM
Package arrived, many thanks !
harvest14 (01-19-2018)
Old 02-20-2018, 03:15 PM
Lyndon1116's Avatar
Default Fitting
King Charles
Did you ever get a chance to fit the parts back into the roof.
Originally I asked about part 9, but I meant part 3. I'm keen to know how it's supposed to attach to the whole kit......
If you've effected the repair can you let me know how it all went together.
Lyndon
Quick Reply: Overhead console piece.
