Overheating, dumb tstat question.
Old Oct 25, 2015 | 08:14 PM
LowellLamb's Avatar
Default Overheating, dumb tstat question.
Chasing an overheating condition. Replaced the stat, no help. Got new water pump to put in.
So, just in case, while I've got it drained again, which way does the stat face? Springy end toward engine? Or else?
Thanks.
Old Oct 25, 2015 | 08:44 PM
harvest14's Avatar
Default Does this help?
If you have an X308 Jaguar then you are in the right forum and the attached picture should help.
Attached Thumbnails Overheating, dumb tstat question.-x308-thermostat-housing.jpg
Old Oct 25, 2015 | 08:55 PM
motorcarman's Avatar
Thanks.
The thermostat has a bypass 'shut-off' on the 'springy-side'.
It needs to shut off coolant flow when the thermostat opens.
You can see the hole in the back of the t-mostat housing.
bob gauff
wolfhamm
Nov 14, 2021 02:06 PM
GrahamJagX
May 16, 2019 04:44 PM
NCamie
Oct 31, 2015 10:38 AM
JaguarSV8
Oct 25, 2015 01:47 PM
deelli
Oct 22, 2015 11:05 PM
