Oxygen sensors (upper)?
Old Aug 19, 2009 | 01:38 PM
chupacabra's Avatar
Default Oxygen sensors (upper)?
hi everyone. does enybody know how to check oxygen sensor in home conditions (I guess it's possible to do with tester or? ) if yes then witch contacts I should check and what is the normal voltage ( or whatever i should check...ohms?) And second thing... there are some kind of "universal" o.sensors, can i ajust it to my jag or paying 200$ for the sensor is the only whay to deal with it?
Thanks.
Old Aug 21, 2009 | 11:02 AM
ken@britishparts.com's Avatar
I don't know of anyway to "home" test them. I'm sure you can.
$200 for a heated 02 sensor isn't bad. You won't get too much cheaper than that.
Old Aug 21, 2009 | 11:18 AM
Namor's Avatar
here you go. hope that helps.
http://www2.partstrain.com/store/?N=...ref=partfinder
Old Oct 29, 2009 | 03:08 AM
Icebreaker's Avatar
I got mine from amazon at $60.00 each, they are made by Bosch too.
mrplow58
Jan 21, 2024 05:53 AM
Steviedee1st
Nov 28, 2023 06:32 PM
NTL1991
XJ40 ( XJ81 )
Sep 20, 2015 06:22 PM
RoyLittle0
Sep 17, 2015 01:05 PM
KarimPA
Sep 3, 2015 07:32 PM
