P0442 - Smoke Test
Old Sep 10, 2021 | 10:32 AM
pcolapacker's Avatar
Default P0442 - Smoke Test
Have P0442 (small EVAP leak) code. Used to have P0455. That went away when I took off canister control valve and cleaned. Guess P0442 always there and was covered up by P0455. Planning on doing smoke test with a cigar and hand suction pump. Anyone tried this. Since CCV is normally open, figured I'll connnect up there.
Old Jan 7, 2024 | 04:16 AM
ForTheLoveOfCars's Avatar
did you find anything 2 years ago? Dealing with the same thing here
Old Jan 9, 2024 | 12:53 PM
Check out my other post at https://www.jaguarforums.com/forum/x...achine-256573/
Where the fitting goes into the cannister there are o-rings. Went to hardware store and found some of same size. Fixed leak and code.
Z07Brandon
May 7, 2021 10:05 AM
cyber3d
Jan 2, 2019 01:07 AM
Volbrewer
Jun 18, 2018 06:37 PM
Dell Gailey
Aug 18, 2017 04:10 PM
