P1000 code won't go away - Please help!
Old Mar 23, 2017 | 03:00 PM
Don B's Avatar
Originally Posted by smtguy
Hi Don,
No, it never resolved, and I have done alot of driving since my original post. I got busy with work, so I have not been back to it, but will have to soon as my smog test is coming up! I almost suspect the ECU at this point, but have no data to support that suspicion.
Do you have any other ideas?
Hi Scott,
After conducting several different diagnostic drive cycles, I finally got this '03 X308 to flag P1649, which IDS says has to do with a flash memory problem in the ECM, and the DTC Summaries Guide says indicates a problem in the ECM to DLC circuit, either a short to ground or a short to B+ voltage. So my next step is to investigate those circuits before swapping in another ECM.
BTW, Torque Pro can read some of the Mode $06 data and it indicates that Tests $0a and $22 are not completing because the components are out of range. TID $22 has to do with the EGR but I haven't found the Jaguar documentation for TID $0a yet.
Has your car flagged any codes other than P1000?
I'll let you know what I find.
Cheers,
Don
Old Mar 24, 2017 | 08:49 AM
smtguy's Avatar
Hi Don,
No I am just getting the P-1000 over numerous resets. Everything else completes. I have seen the "components out of range" message but I don't know how to interpret that so I can fix the problem.
Many thanks for the help and information.
Old Mar 24, 2017 | 09:08 AM
Don B's Avatar
I am getting:
TID $0a CID:$11 NOT OK
Sensor period
Max 33,423
Current 65,423
In addition to the above, my car also shows:
TID: $22 CID:$11
Max 37,683
Current 65,535
After performing three different diagnostic drive cycles, Torque Pro now shows "FAULT PENDING" along with the P1000.
IDS shows the P1649 code along with P1000, but after more research I'm beginning to suspect that the P1649 is just a spurious code, perhaps from connecting and disconnecting three different scanners multiple times today. I suspect P1649 is not the reason the monitors are not completing in order to flag P1111.
I found some Mode $06 data on pages 12 and 13 of the attached DTC Summaries Guide.
JagV8 mentioned somewhere that the TOPix website has some Mode $06 data so I'm going to see what I can find there.
Cheers,
Don
Old Mar 24, 2017 | 09:35 AM
motorcarman's Avatar
Jaguar did have issues with some cars in this MY range.
Maybe a 're-flash' of the ECM????
Read through some TSBs for ideas on this.
bob
File Type: pdf
File Type: pdf
Old Mar 24, 2017 | 04:12 PM
JagV8's Avatar
I've found on some cars that not all mode 6 data is supported / delivers meaningful data - but sorry I don't know for these cars (well, their PCMs).
Bob's a very good source for ideas of course
Old Mar 24, 2017 | 07:20 PM
Don B's Avatar
Since this car is new to me, I'm going to start with a "Jaguar electrical tuneup," by cleaning grounds and battery power connections and the ECM connectors. If the monitors still won't complete and flag P1111, I may try reflashing the ECM per the TSB Bob provided.
Cheers,
Don
Old Mar 24, 2017 | 08:08 PM
ericjansen's Avatar
I have read about the same issues on the x350, so the issues maybe initially moved over to the new model.
If short of ideas and solutions, maybe their forum will give you some clues.
Old Apr 9, 2017 | 08:56 AM
  #28
Don B's Avatar
Update: I found the reason that P1000 would not resolve to P1111 on our X308.
As I was giving the engine bay a careful inspection, I discovered that one of the two mounting ears that secure the air intake pipe to the throttle body had broken around the head of the screw, allowing that side of the pipe to be just loose enough to create a small air leak between the end of the pipe and the rubber seal.
I added a large washer under the head of the screw to re-secure the pipe, and when I scanned for codes a few days later the magic P1111 had appeared.
Now I can get the car through emissions testing so I can get it licensed. Yeah!
smtguy,
Since the Mode $06 data on your car was very similar to ours, it would be worth checking for a small air leak in your intake plumbing.
Cheers,
Don
Old Apr 9, 2017 | 09:28 AM
JagV8's Avatar
Did you not have fuel trims that showed a leak?
Old Apr 9, 2017 | 09:46 AM
  #30
smtguy's Avatar
Don,
Where is the pipe that you mention? Are you talking about the plastic snorkel?
I replaced mine with a new one thinking that would do it, but it didn't make any difference.
Thank you!
Scott
Old Apr 9, 2017 | 10:41 AM
  #31
Don B's Avatar
Don,
Thank you!
Scott
Hi Scott,
Yes the snorkel, part 5 in this diagram. The lower end connects to the MAFS and the upper end connects to the throttle body. You can see the right mounting ear in the diagram. On our car the left ear had broken through around the head of the screw (7) so the joint between the end of the pipe and the rubber seal (6) was no longer air tight.
JagV8,
Great question about the fuel trims: they were the clue that led me to search for a small leak. LTFTs were B1 10.9 and B2 14.8. I haven't measured them since re-securing the air intake pipe but will be surprised if they aren't lower. I also won't be surprised if there are other remaining issues. For example, I think I'm hearing a slight exhaust leak on B2 (from the driver's seat - I haven't listened in the engine compartment yet).
Cheers,
Don
Old Apr 9, 2017 | 01:28 PM
  #32
JagV8's Avatar
Should be better than they were. Worth checking when you have time.
Old Jun 11, 2017 | 12:10 AM
  #33
charles glass's Avatar
Default same problem exactly
I have a 2002 xkr
I have exactly same problem & same diagnostic exactly as yours with torque pro.
have driven my car for 150 miles still showing the p1000
my car inspection very soon, so if you sorted your problem out, please let me know!
Old Jun 11, 2017 | 08:22 AM
  #34
smtguy's Avatar
Hi Charles,
I would like to tell you that my XJR passed the P1000 code to reset, but unfortunately it has not. Since I have aftermarket cats currently on the car I, am going to change to the stock Jaguar cats and 02 sensors this week to see if that makes a difference. It seems like I have done everything else.
I am keeping my fingers crossed at this point, and I will post the results.
Old Jun 11, 2017 | 08:28 AM
  #35
WhiteXKR's Avatar
Scott and Charles: Did the test station provide a report of which tests are failing? This will help me or others provide some specific advice.
Old Jun 11, 2017 | 09:15 AM
  #36
JagV8's Avatar
An OBD tool can show which monitors have not set and you might get pending codes.
Old Jun 11, 2017 | 10:52 AM
  #37
Don B's Avatar
Originally Posted by charles glass
I have a 2002 xkr
Hi Charles,
I don't know if you saw my posts #28 and #31, but I was able to resolve this issue on our '03 XJ8 by tracking down a small air leak.
Cheers,
Don
Old Jun 12, 2017 | 08:59 AM
  #38
smtguy's Avatar
White XKR,
With Torque Pro I am getting:
COMPONENTS: INCOMPLETE (See first post in thread)
which leads to:
Sensor period
Max 33,423
Current 65,423
Since I have no idea how to interpret this, I also have no idea what to do about it. All I can think of to do is change back to the stock cats, and try some new 02 sensors.
Scott
Old Jun 12, 2017 | 10:18 AM
  #39
Don B's Avatar
Scott,
If you haven't done so already, you might try monitoring Short Term Fuel Trims (STFT) with Torque while, with the engine running, you aim an unlit but open-valve propane torch along every part of the air intake, intake manifold gaskets, fuel injector O-rings, breather hoses, vacuum lines and EVAP components that you can access to see if the STFT shifts rich at any point.
Starting fluid or other flammable spray can be used as well. I've never had a problem with these methods, but it's smart to keep a fire extinguisher on hand (or even a garden hose) just in case.
If you know an independent shop with a smoke machine, that's a great way to find the smallest of leaks. You can actually make one for less than $20 - search YouTube.
Cheers,
Don
Old Jun 12, 2017 | 11:49 AM
  #40
this is the only X i got from torque pro diagnostic.
Originally a fault had shown engine running lean, & check gas cap, but a refuelling solved that issue. So now, all i have is P1000.
Thank You All!
