P1647 but no Check Engine light
Old Apr 27, 2021 | 01:52 PM
timskipper's Avatar
Default P1647 but no Check Engine light
I'm getting a P1647 code, but no noticeable change in fuel economy and no check engine light. There's plenty of threads about this code and the O2 sensor but I can't find any that don't also mention the CEL being lit. Mine isn't - could it be anything else than a busted O2 sensor?
Old Apr 27, 2021 | 05:02 PM
JagV8's Avatar
So long as your MIL works then you're not seeing a current code and can ignore it.
Your tool SHOULD make this clear!!
Old Apr 27, 2021 | 05:43 PM
timskipper's Avatar
Hmm. If I clear the code though and re-scan, it goes away. When I go for a drive, it comes back.
Old Apr 28, 2021 | 02:04 AM
JagV8's Avatar
First, stop clearing it. It's not helping you.
Then do some warm ups, probably different days.
Chances are you'll get the code & MIL in which case you need to FIX the car.
Maxie
May 6, 2018 05:41 PM
RKnight
Jan 17, 2018 11:31 AM
mrtalkradio
Dec 19, 2011 07:12 PM
dspguitar
Feb 18, 2011 02:04 PM
williespinks
Aug 29, 2010 11:14 AM
