Paint advice please
Old Oct 6, 2019 | 01:37 PM
Steve W's Avatar
Default Paint advice please
My 02 XJR has a few spots where the paint is fading. In this picture it's right behind the back window. Can a paint shop touch it up and still have it blend in with the rest of the car's paint?
Old Oct 6, 2019 | 01:55 PM
jackra_1's Avatar
Not really.
New paint will look different from older paint depending on how old it is.
The other issue is the clear coat. Getting a patch of clear coat to "feather in" with original clear coat is extremely difficult to do properly.
Getting that complete panel done would be the best bet I think and even tho a slightly different "shade" to the rest would not be too bad.
Old Oct 6, 2019 | 03:03 PM
Carnival Kid's Avatar
I think a good paint shop would want to repaint and coat the panel and trunk lid, and also feather into the tops of the rear fenders to do it right. And it wouldn't be cheap. I'm guessing $650-$1,000
Cheaper shops could make it look better than it is now for less, but you get what you pay for.
Old Oct 6, 2019 | 05:04 PM
Fraser Mitchell's Avatar
Paint work is almost all labour, although the paint they use today is very expensive too ! I recently had the hood repainted on my previous car, a 2007 X358, due to stones damage. It cost around £400. If the base coat is undamaged albeit faded, then it is just a case of removing the clearcoat, applying base coat, then replacing the topcoat. There may be a slight variance in the shade of the new and old. It all depends on how much of a perfectionist you are. If you want it perfect, then you'd be looking at refinishing the trunk lid and the tops of each rear wing.
Old Oct 6, 2019 | 05:47 PM
King Charles's Avatar
I tried the paint by panel to fix clear coat failure came w/ my X308. Shop charged $300-350 per panel but after a year or 2 it really drew my eye as far as not having uniform shine. I opted for the complete paint job in March of this year.
Old Oct 7, 2019 | 10:04 AM
Steve W's Avatar
How much did the total repaint job cost?
Old Oct 7, 2019 | 08:19 PM
$3200 @ a very small indy shop I was quoted twice that @ chain shops. I'm in eastern NC, $ well spent.
GrahamPhotog
General Tech Help
Sep 6, 2014 01:02 AM
walkman1
Aug 30, 2013 12:18 PM
jagosaurus
Sep 25, 2012 06:50 AM
tmny277
Aug 5, 2012 09:53 AM
Wild Bill
Aug 15, 2011 02:50 PM
