Part Load Breather Hose
Old Jun 2, 2016 | 08:44 PM
larney's Avatar
Default Part Load Breather Hose
Pardon my stupidity but how the heck do you open/close these clamps? It's the end that goes into a vacuum port. Is there a special tool? Sorry for such a simple thing...
Old Jun 2, 2016 | 09:01 PM
harvest14's Avatar
Someone more experienced will hopefully soon chime in, but I don't "think" those are re-usable clamps. I think they are installed at the factory and have to be replaced with more traditional clamps.
I pry them off with a small screwdriver, needle nose pliers and possibly a small pick. I then replace it with a standard (worm style?) screw clamp. Maybe someone will explain a better way to remove them; I'd be curious.
By the way, did you get the throttle body connection snapped into place ok?
Old Jun 2, 2016 | 09:05 PM
larney's Avatar
I think you are right. I sent the picture to a friend and he said cut or pry off. That works for me. Yes I did. Put some lube and pushed REALLY hard and snapped right into place. Wow that was more work than it needed to be.. Thanks.
Old Jun 3, 2016 | 05:38 AM
test point's Avatar
Easily removable. There is a special tool but squeeze gently with pliers and pry up the latch with a small screwdriver or a pointy tool. Take a moment to inspect while squeezing and it will be obvious how they work.
Old Jun 5, 2016 | 02:28 AM
dc4prez's Avatar
nail pincers work perfect
JTsmks
Jul 5, 2016 09:04 PM
Oceansidesurf
Jun 9, 2016 02:58 AM
Doug
Jun 7, 2016 07:07 AM
orangeblossom
Jun 5, 2016 05:31 PM
Lubino Do Rego
May 14, 2016 02:43 AM
