Passenger front window problem
2000 xj8 x308
I recently had some body work done on lower front body passenger side by the wheel arch now my front window dose not work from switch but it works from drivers side master switch. Things I have done so far changed switch door module did not work so change them back to original ones changed fuse #15 25 amp as it was blown still not working any ideas would be appreciated thanks jrb53
Thanks for your reply’s I have done hard reset every time I have tried something I have power to the switch so must be a brake in the wiring I’m going to have it checked out with an auto electrician will post more when I find the problem thanks
doc
Oct 13, 2015 09:16 PM
