Passenger window
Old Jan 6, 2020 | 01:31 PM
Leovt's Avatar
Default Passenger window
Good day all. I am fairly new here but I have a problem with the passenger window. I set the steps, but when I start the car the window wants to go all the way down and will resist efforts to bring it up. Is this related to the latch switch?
thanks
Leo
00 xk8 conv and 04 xjr
Old Jan 6, 2020 | 01:53 PM
avern1's Avatar
My thoughts are one of the 2 window switches is stuck in the down position. Now the hard part which side driver or passenger. I think I would start with spraying both switches with electronic cleaner and see if it will clear the problem. If it doesn't have any effect then it it time to remove door cards and disconnect each one separately and determine the bad one.
Old Jan 6, 2020 | 01:55 PM
Leovt's Avatar
Thanks. I had spent money replacing the driver's module of switches. However no luck. I will try the other side.
Old Jan 7, 2020 | 06:47 AM
SamtheSham's Avatar
I have a similar problem, but sporadically. Occasionally, after I have lowered my top, then raised it, when I start the car next, the passenger window will lower. I can only raise it by activating the driver's side switch, twice(first time does nothing). After this, windows on both sides lower normally, using either switch. Stray electrons??
Old Jan 7, 2020 | 09:14 AM
Leovt's Avatar
Thanks Sam. Beginning to believe in gremlins. It does seem weird, but I have decided to put in a new battery, since it seems to be a source of many issues .
Old Jan 7, 2020 | 12:10 PM
SamtheSham's Avatar
I have a relatively new battery, so that is not my problem. The window problem persists,even today when I started out, the passenger window dropped and had to be raised by depressing the passenger switch twice. Afterward, either side switch operates the window normally. Go figure????
sh500
Jul 15, 2020 07:22 AM
SamtheSham
Nov 11, 2019 08:00 AM
doc
Oct 13, 2015 09:16 PM
oldmots
Aug 9, 2014 12:17 PM
RichmondXK
May 22, 2011 12:06 PM
