Pedal Position Sensor & Throttle Body
Old May 13, 2018 | 11:09 AM
Len Apcar's Avatar
Default Pedal Position Sensor & Throttle Body
I have a faulty pedal positon sensor that was causing all the issues -- limp home, gearbox fault, no /ASC.
Diagnosis was pedal position sensor. I came to believe the only solution was to bight the bullet and buy a new throttle body. Prices ranged from about 2400 to 3000 USD.
Have not put it in yet. I am thibking that there are other components of the throttle body that could age out similarly and best to replace the whole shebang.
Thoughts?
Old May 13, 2018 | 11:43 AM
Lady Penelope's Avatar
There are 2 TPSs on the X308 and can be read very easily with a meter . Do you have any codes ?
Would have to verify the correct year in the drawing below
Old May 13, 2018 | 12:42 PM
avern1's Avatar
Use the advance search feature with key word throttle body. You will find threads for a company that rebuilds the throttle body for a lot less than a new one. They have a very good reputation for service.
Old May 13, 2018 | 04:13 PM
vincent661983's Avatar
There is a TB rebulre service on ebah, just serach it.
Item number 131229240389
bmcinsd
Jul 29, 2017 01:03 PM
'05 STR
Feb 14, 2016 08:33 AM
juha_teuvonnen
Dec 17, 2014 09:35 PM
Erndiego619
Apr 5, 2012 11:05 PM
