Picked up another one! Does not go into closed loop
Old Jun 27, 2015 | 06:03 PM
dsnyder586's Avatar
Default Picked up another one! Does not go into closed loop
Hi All,
I picked up a 2000 XJ8 for $800- owner said broekne timing chains, but I found it to be Bore Wash. (don't worry, I replaced the tensioners anyway) Here's the deal-
Car starts and runs fine. My reader shows it running in open loop, no readings from the o2 sensors or any mixture readings. Car is up to temp, I tried two different readers FYI.
Not sure where to start, as I need to get it through the paces so I can get it smogged.
Old Jun 27, 2015 | 06:38 PM
test point's Avatar
Is it setting codes?
If there are not codes perhaps you are not linked to the ECM data that provides the fuel trim information. Can you see any of the expected data other than fuel trim? Temp, rpm, etc.
Old Jun 27, 2015 | 06:46 PM
dsnyder586's Avatar
I get temp, TPS, and a couple others... I am wondering if maybe the reader is SHOWING OL, but it is actually running closed... Going to check the connector and bulkhead connection tomorrow as well as the brake switch to see if there is an issue there. It is running fine, but I need to get it to smog without any codes. I'll post the codes when I pull them tomorrow.
Old Jun 28, 2015 | 09:44 AM
JagV8's Avatar
You can also look to see which OBD monitors have set and which not. Those can be a hint to what may be wrong.
If there are no actual codes, next look for pending ones.
Old Jun 28, 2015 | 11:06 AM
dsnyder586's Avatar
Ok- P1647 appears about 20 seconds after resetting the codes.
Old Jun 28, 2015 | 11:40 AM
dsnyder586's Avatar
Swapped o2 sensor connectors and now it's P1646... On the hunt now.
Old Jun 29, 2015 | 11:14 AM
dsnyder586's Avatar
Swapped them and getting P1647 again, so it looks like I found the winner. Still wont go into closed loop... Here are my readings:
Open loop! Temp is up after a freeway drive.
O2 readings jumping around, so shouldn't they still be good?
Anybody kno what EQ ratio is and why it's stuck at 999?<br/>
Old Jun 29, 2015 | 02:26 PM
dsnyder586's Avatar
RESOLVED-
I switched the driver's o2 sensor with one from another car and BAM- everything lights up normal and I am getting readings from all sensors.
Old Jun 30, 2015 | 09:26 PM
X7.62x51's Avatar
Originally Posted by dsnyder586
Hi All,
Wow !
Awesome deal
Old Jul 1, 2015 | 09:55 AM
dsnyder586's Avatar
Thanks!
Old Jul 3, 2015 | 11:45 PM
dsnyder586's Avatar
On a side note- I was able to trigger all the emissions test cycles by starting the car, idling for 7 minutes, then driving regularly for 3 minutes, then driving 10 minutes at 55MPH and finally driving 35 MPH for 30 seconds- hope this helps someone!
bamforp
Aug 14, 2024 05:36 PM
99xk8guy
May 28, 2024 09:36 PM
Rivguy
Nov 13, 2022 02:55 AM
Jaguar Forums Editor
Jaguar Press release
Sep 14, 2015 11:18 PM
