Picked up an XJR with a blown headgasket. Should I do one side or both?
Old Mar 25, 2015 | 08:43 AM
adam699's Avatar
Default Picked up an XJR with a blown headgasket. Should I do one side or both?
Only the drivers side is blown so I'm wondering if I should do both or just one.
Edit: I guess I should've proofread the topic.
Old Mar 25, 2015 | 08:46 AM
Fixed it for you. :-)
Old Mar 25, 2015 | 01:24 PM
Brutal's Avatar
Both, most of the work for one applies to both and i would pull both heads, new gaskets, tensioners, guides, chains, valve job and spring pressures set, clearanced, etc. On the r it is not the way to go if you want to keep it to just do half.
Old Mar 25, 2015 | 03:26 PM
RJ237's Avatar
Not sure what year, but use 4.2 head gaskets, even on a 4.0.
Old Mar 25, 2015 | 07:34 PM
sparkenzap's Avatar
I did both- I recommend doing just one!
Old Mar 25, 2015 | 07:44 PM
Nookieman's Avatar
I would make the decision after pulling the first head. Buy the parts for both. if the first one needs valve work or needs to have the carbon cleaned, do both.
Old Mar 26, 2015 | 04:53 PM
dsnyder586's Avatar
Both- you are already in there, and if you don't there will always be that nagging little voice in your head telling you that you should have...
Old Mar 26, 2015 | 08:02 PM
Jhartz's Avatar
. . . and there is nothing like that nagging little voice ('cept your wife, often same voice). I side with Ross, do one side; happy, close it up; not, do the other side.
Old Mar 27, 2015 | 06:54 PM
sparkenzap's Avatar
I rounded a bolt head on the side I did not need to do! So I am highly biased...
Old Mar 27, 2015 | 09:58 PM
pdupler's Avatar
I tend to suffer from the "while I'm at it" syndrome. To replace a rusted brake line on an old Corvette required lifting the body. Two years and ten grand later I'm staring at a completely restored chassis and thinking what a shame it would be to put the body back on such a beautiful chassis without stripping it all the way back to bare fiberglass and having it repainted. It doesn't look bad and I originally had no plans to do anything to the body but after all, this would be the time to do it just like the factory. And while I'm at it.....
Old Mar 27, 2015 | 10:35 PM
Nookieman's Avatar
+1
Old Mar 28, 2015 | 04:56 AM
xjay8's Avatar
Do you want a cheap fix, or do it properly?
Common sense would dictate that you do both sides and check a few other issues at the same time.
Considering the pressure these engine are under and being a performance
vehicle they do get a hammering ;o]
Old Mar 28, 2015 | 04:41 PM
plums's Avatar
Would a different socket have avoided the rounding?
Not criticising your work or tools, but very curious.
Old Mar 28, 2015 | 04:43 PM
plums's Avatar
What year?
And asl always, can we have pictures when you get that far?
Guess you already know about replacing those heater hoses
... "while you're in there".
Old Mar 29, 2015 | 01:20 AM
sparkenzap's Avatar
plums:
Like most screw ups, it happened when I got in a hurry, after many hours work and I let the wrench get misaligned.
The new bolts are torx or sockets heads as I recall, so the Jag boys must have realized the hex heads were not such a great idea.
Old Mar 30, 2015 | 02:19 PM
bdboyle's Avatar
It's called 'Shipwright's Disease'. BTDT with the Lotus Europa I bought 8 years ago. Thought it would be a rolling restoration. Turned into a bare frame restoration. The story is on my website under the journal for 693R. Somehow, that's always how it goes, right?
Old Mar 31, 2015 | 07:46 AM
adam699's Avatar
I guess I'll tear into it and see. Probably will do both sides. I just hate disrupting exhaust mainfolds. It's a '98 with about 130k miles on it. The car is really well documented by the previous owners mechanic. I intend to resell it once I fix the headgasket, I'll probably rebuilt the supercharger while I'm at it too. I got a good deal on it as the previous owner was recovering from cancer and going through foreclosure and didn't have the money to fix it. She was happy to see the car go into Jag enthusiasts hands I promissed to take her for a ride once I fix it all up.
Are the headbolts reusable or are they torque to yield?
Old Mar 31, 2015 | 06:54 PM
plums's Avatar
TTY. In theory resusable once. The manual says
that dealerships are supposed to punch the bolt
head if they have been reused so that they are
discarded the next time around.
Old Apr 1, 2015 | 10:27 AM
adam699's Avatar
Do the Lincoln Ls bolts/gaskets work?
Old Apr 2, 2015 | 09:35 AM
dsnyder586's Avatar
The LS bolts do (used them a couple times) I do not think the head gaskets will tho- I don't recall why, but I used the later Jaguar ones.
