Poly Subframe Rear Bushes
Old Aug 12, 2025 | 07:48 AM
ChristmasGT's Avatar
Lightbulb Poly Subframe Rear Bushes
Hey everyone,
Given that MNC2370AC is pretty difficult to find for the front subframe, I've reached out to Polybush to see if they had any ability to make a replacement. While I'm going through the process, I just wanted to see if there was anyone else that had interest for a pair of them.
Looks like they would need to sell around 100 bushes to get off the ground due to cost.
Old Aug 12, 2025 | 09:24 AM
Highhorse's Avatar
Old Aug 12, 2025 | 09:28 AM
Hey Highhorse,
Those are all the same URO manufactured aftermarket part that are typically undersized:
https://www.jaguarforums.com/forum/x...source-281436/
https://www.jaguarforums.com/forum/x...2370ac-258639/
Old Aug 12, 2025 | 10:51 AM
Addicted2boost's Avatar
Unless you’re making a race car out of it, I’d stay as far away from polyurethane bushings as much as possible. Single worst mistake I made on my GN about 20 years ago. I know that we're currently very limited on quality parts. If I was in your situation, I’d get the undersized URO bushings. When you get the old ones out, I’d remove the old rubber and reuse the old lead (??) casing around the new URO bushings to make up the slop. Unless your bushings are absolutely destroyed, I’d maybe lower the subframe enough to install some rubber inserts to stiffen/support the existing one until URO has these available at the end of 2026.
Old Aug 12, 2025 | 11:12 AM
Jhartz's Avatar
Agree: On my first X308, in 2002, the dealer tech switched out the bushings with poly: rode like a jacked up Ford p/u . . .
Old Aug 12, 2025 | 01:29 PM
Highhorse's Avatar
Originally Posted by ChristmasGT
Hey Highhorse,
I was unaware these came undersized, ...but it wasn't specified. This is something I may have to do in the near future, so an FMI to me.
Old Aug 12, 2025 | 02:43 PM
Ken Cantor's Avatar
I will echo Addicted2boost and Jhartz...
I had a indie change OE to poly bushings on an '87 V12 VDP and while I wouldn't say the ride went to $h!t, it was noticeably less compliant/comfortable with little or no commensurate increase in handling albeit that is a non-track tested conclusion.
I still miss that car as much I enjoy/enjoyed both of my 92's. It was always what I call "a happy car" that seemed to want to be driven and not just a "car that you want to drive" if that makes sense.
Old Aug 12, 2025 | 09:56 PM
aquifer's Avatar
Google shows quite a few rubber ones available, but they’re a little pricey. I replaced mine several years ago. At that time, they were still available from Jaguar which is what I suggest if you can find them. I generally don’t like poly bushings because of the harsh ride, so I suggest going with rubber, even if they’re not OEM. Just my $.02.
Old Aug 13, 2025 | 06:18 AM
Hooli's Avatar
Another thought for polybushes, although less relevant to a road car.
Years ago I used them on a LR as people said they were great etc etc, then drove in sandy places & they wore out in no time.
Old Aug 16, 2025 | 08:36 PM
stuizzy's Avatar
I replaced the bushes on my car and fixed them in place with Loctite 638. Have put a few hundred miles on the car without issue
Vauxi
Jun 17, 2024 12:31 PM
MCFastybloke
22
Mar 3, 2022 08:44 AM
Melb2018
Jul 10, 2019 12:15 AM
Jagluvr
Jun 7, 2018 04:47 PM
jaypee_6680
Jun 23, 2014 07:15 AM
