Poor Gas Mileage
Old Dec 15, 2011 | 08:29 PM
ant17's Avatar
Default Poor Gas Mileage
Just had the trans replaced, had a bunch of codes I cleared.
Getting 9.6 mpg city.
Anything I can do to reset or increase the mileage?
Not sure why its so bad.
Did a TB clean.
thanks
Old Dec 16, 2011 | 03:19 AM
Cadillac's Avatar
I don't like to sound like a pundit but make sure everything is tight fit . I got a poor fuel consumption in my dad's car and that turned out to be a loose hose and broken PCV Hose
Old Dec 16, 2011 | 06:39 AM
Sean B's Avatar
Check the O2 sensors are connected correctly - the centre plastic cover under the bonnet needs taking off, and look down behind the engine where it joins the gearbox, the O2 sensors connect up on a bracket there. If they're not connected it would throw a code though?
Would have been nice to see what codes you cleared! have they come back and can you post them? It would help, greatly.
Old Dec 17, 2011 | 06:41 AM
ant17's Avatar
These are the codes I cleared:
1. P 1722
2. P 1316
3. P 1000
4. P 0732
5. P 0175
6. P 0171
7. P 0308
8. P 0307
9. P 0300
They have not come back, I switched 2 O2 sensors, and yesterday did a hard reset.
I believe the 2 trans codes were from the old trans.
Old Dec 17, 2011 | 08:36 AM
Sean B's Avatar
So how is the gas mileage now ant? was the advice useful, a rather short info'less statement from you?
Followups are valuable in fixing faults, it's not just for your car!
Old Dec 18, 2011 | 07:52 AM
ant17's Avatar
Infoless??? Not sure what you're talking about.
Mileage went up.
Old Dec 18, 2011 | 07:40 PM
pdog2000's Avatar
How did you do the hard reset and did you clean your MAF?
Old Dec 19, 2011 | 12:04 AM
plums's Avatar
Mileage went up.
And what is the specific mileage?
When you asked the question it was 9.6mpg city.
What is it postfix?
Old Dec 19, 2011 | 05:19 AM
ant17's Avatar
What is it postfix?
Mileage went to 13.7, but I still want to measure the old way at next fill up.
Old Dec 19, 2011 | 05:20 AM
ant17's Avatar
Yes, cleaned the MAF, held the negative cable to the Pos. terminal 10 sec.
Old Feb 28, 2012 | 09:29 PM
ant17's Avatar
Mileage back down to 10mpg around town.
Not sure why its so low.
Old Feb 28, 2012 | 10:16 PM
domer94's Avatar
i just recently went through exactly what yo are talking about. the independent jag specialist who did the trans used his equipment to clear all th prior trans codes. the 0131 i took care of by replacing the pass side upstream 02 sensor , the 0171/0175 i took care of by cleaning the mass airflow sensor / intake piping and t-body. the p1000 cleared when i did the hard reset. for good measure i also disconnected the pos and neg batt cables and let it sit for about 20 min. so far nothing has returned. dont know if it was related , but i replaced any vacuum hose i could find with silicone hose. the ones around the t-body were very brittle and deteriorated.
Old Feb 29, 2012 | 05:35 AM
ant17's Avatar
What did you get the mileage up to?
n2audio
19
Jan 20, 2025 09:35 PM
bdboyle
Sep 16, 2019 05:58 PM
jagtoes
Apr 22, 2016 07:37 AM
jagtoes
Oct 14, 2015 06:15 PM
JTC3400
Sep 29, 2015 05:03 PM
