possible BCM issue? symptoms listed....
Old Sep 26, 2018 | 01:32 PM
Sean B's Avatar
Default possible BCM issue? symptoms listed....
2002 XJR - Don't use it often so it sits for long spells. Hooked the battery - removed the fuel pump relay, spun it then replaced the relay and started it up.
Problem 1 - mirrors are offline.
Problem 2 - interlock solenoid does not respond to brake pedal so I've to manually unlock the gear shifter. Once in gear I noticed it took a lot longer for the global locking to lock the doors.
Problem 3 - steering column does not respond to the position switch, but will move to memory positions via drivers door switchpack.
Thought I'd post this as someone may have a quick fix, it's gone dark here and I'm through for the day, but planned on chasing earths when I can get a look at the wiring diagrams, but from memory all 3 are controlled via the body control module, if so I've never replaced one - do they fail?
Cheers for any insights Guys.
Old Sep 26, 2018 | 03:50 PM
RJ237's Avatar
A long shot, but try a hard reset, then turn the ignition on for 30 sec. then off again before doing anything else. Supposedly to allow ECU to complete communication with other modules.
Old Sep 27, 2018 | 10:14 AM
Sean B's Avatar
So this morning I went through all fuse boxes (apart from the ECU) and found 1 15A blown on one of the heal board boxes. Tried the offline stuff - the column responded a little, but no mirrors or interlock...
Then tried a hard reset - systems seemed to be confused with fragmented memory settings? Then one by one things came back on line - gotta thank RJ237 for the suggestion.
Items affected by fuse and memory settings
Powerfold mirrors
Power column
Shifter Interlock
Trunk lid lights
Interior C pillar lights
CD player
I will update with which fuse effects these parts - also the reset was pos+ cable to neg- for 30 seconds, then ignition on for 1 minute. Cycled the steering column, mirrors and shifter and everything is now working beautifully - it's sharp responses, not sluggish as it seemed to be prior to the reset.
Can a mod amend the title of the thread to fixed please?
BurgXK8
Sep 6, 2023 11:04 AM
Andrew Fitch
Sep 19, 2022 12:12 PM
Don B
36
Aug 28, 2020 05:20 PM
turkeyfly
Jul 12, 2015 08:11 AM
