Potential New Owner
Old Jun 27, 2012 | 09:36 PM
tomsawyer's Avatar
Default Potential New Owner
Hi All - I may become a new member to the forum. I plan on looking at a 2000 VDP w/ 32k tomorrow currently owned by the original owner. I believe the engine is the 4.0. Owner indicates the body is mint and so is the interior.
I have read up on the the various issues pointed out (transmission & engine); however, I wanted some advice as to what other things I need to look out for. Obviously, I cannot look inside the tranny or engine so is there another way to tell if a car has these issues?
Also, are there any other trouble spots I would need to be aware of that you recommend I check out (suspension, bushings, etc.)?
Were there any recalls for this vehicle?
Basically this car is owned by a woman who lives in the same town she works in. That's why is has such low miles. If I buy the car, I plan on using it sparingly as I have other cars that I use for commuting. The VDP would be used for weekend pleasure driving.
Thanks to all who answer
Old Jun 27, 2012 | 09:47 PM
Cybersib's Avatar
Hope you get it! You're gonna love it! Sorry I can't give you much on what to look for with that late of a model (mine newest jag is an 87, and my other is a 1950!). All the best to you and best of luck with the acquisition!
Old Jun 27, 2012 | 10:46 PM
mrlovt's Avatar
I own an '01 VDP and love it. It is pushing 160,000 miles and running just fine. As far as issues with a 2000 model, the most serious possible problems could involve the transmission or Nikasil engine. You can search the X308 forums for more info on these issues.
With so few miles, I wouldn't worry about the transmission. Low compression due to Nikasil sleeve breakdown should only be an issue if it's been fed high-sulfur fuel. Again, with so few miles, I wouldn't worry too much about it. However, as with any car, run a Car Fax and have a good Jaguar mechanic look it over.
The only other hazard that comes to mind is to mind your ego... you'll get lots of compliments an a beautiful XJ8! Let us know how it goes.
OK, I just noticed that you've already read up on the transmission and engine. Double-check the condition of the upper timing chain tensioners. One other common problem is with the thermostat housing. If the one on that car is NOT aluminum, change it now! The original plastic ones can fail and leave you stranded. You might look for things like minor body rust at emblems and such, sagging headliner, and cold A/C. If I've forgotten something major, I'm sure someone will remind us. Otherwise, like I said, there's not much to worry about!
Old Jun 28, 2012 | 03:04 AM
Cadillac's Avatar
That's like a good deal given that your post about the car suggest me it's in mint conditon . I am interested at your finalizing the deal or not
Keep us updated
Welcome
Old Jun 28, 2012 | 04:04 AM
As it's one owner and still with this original owner, she should have a complete service history from original purchase.
Despite the very low miles, service is interval is 10k miles OR 12 months so it should show 11 services.
Paperwork can tell you a lot.
Old Jun 28, 2012 | 09:15 AM
WaterDragon's Avatar
Wow
Good luck on closing the deal !
Old Jun 29, 2012 | 06:40 PM
mrlovt's Avatar
I just found this on the forums, a must read: https://www.jaguarforums.com/forum/x...k-links-20090/
Best wishes!
BlacXJRcat
35
Oct 21, 2025 03:49 PM
Forcedair1
Sep 8, 2025 01:57 PM
silkcat
Jan 18, 2025 04:29 AM
alextoevs
Sep 20, 2015 05:21 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
