Power Brake not working
Old Jan 10, 2011 | 04:06 PM
sterling's Avatar
Unhappy Power Brake not working
The hydraulic pump is not getting electricity. We've replaced the relay and confirmed that juice is going to the relay, but the electricity doesn't make it to the hydraulic pump or the abs braking system. besides extensive electrical troubleshooting, does anyone have any other ideas or similar problems that have been fixed?
Old Jan 10, 2011 | 05:18 PM
sparkenzap's Avatar
Your description of your particular problem is pretty unclear, but as an answer to what seems to be your specific question,YES, there are known issues with the electical solder joint on the motor leads on the ABS module. Se archives. Other known issues are connectors at wheel sensors. A better description of what synptoms you have will probably get some pretty good response.
Old Jan 10, 2011 | 08:11 PM
motorcarman's Avatar
C1095 is the DTC for the ABS pump motor failure.
Other DTCs will lead you to a different repair procedure.
You need to get the C (chassis) codes read for a good diagnosis or you can keep cleaning or changing parts.
bob gauff
BrentGardner
29
Dec 16, 2024 12:13 AM
Robert1968
Jun 24, 2017 11:16 AM
johnnie ryall
Oct 19, 2015 09:44 PM
Fraser Mitchell
Oct 1, 2015 04:06 AM
larney
Aug 27, 2015 07:54 PM
