Power steering reservoir bushing
Old Jan 3, 2017 | 04:21 PM
skinnypuppy_22's Avatar
Default Power steering reservoir bushing
Does anyone have the part number for the power steering reservoir bushings
Old Jan 3, 2017 | 06:12 PM
I'll answer my own question.. It is part number c2c16681
Old Jan 6, 2017 | 04:17 PM
Jhartz's Avatar
Is this the noise you were referring to, before?
Old Jan 6, 2017 | 05:59 PM
No these bushings have nothing to do with the other noise
. That noise sounds like low on fluid but only in park revved up and turning the wheel I don't actually notice it while driving
Old Jan 7, 2017 | 12:01 PM
Jhartz's Avatar
Look along the frame rail, somebody probably dropped it when they changed the upper shock mount on the port side.
Old Jan 7, 2017 | 01:37 PM
Don B's Avatar
Hi skinnypuppy_22,
It is helpful if you add the year, model, engine type and mileage of your Jag to your signature line so others don't have to ask. Without this information, many questions are impossible to answer accurately.
Regarding the P/S fluid reservoir bushings or grommets, here's a photo of Jaguar part C2C16681:
And on the left in this photo are generic wiper motor bushings commonly available at local auto parts stores that may work for your reservoir. If they're not quite thick enough, then on each end you can add a rubber washer from the plumbing department of a hardware store as shown on the right:
Cheers,
Don
Old Jan 7, 2017 | 04:50 PM
Thanks for that...I found some uro ones that arrived today
. And already installed
D.K
Mar 28, 2020 09:48 AM
StellaLunaGardens
Dec 19, 2016 02:16 PM
xjrjag
Dec 6, 2015 03:52 PM
magmedia
Apr 2, 2015 09:22 PM
Calhale
Sep 25, 2014 07:48 PM
