Programming XJ8 Keys
Old Aug 17, 2012 | 09:31 AM
markocosic's Avatar
Default Programming XJ8 Keys
2002 X308
I have two keys, two fobs.
I have a third key, with transponder chip inside, that is cut but not coded to the car.
Can this be done by anybody other than a dealer? If so, how please!
Thanks,
Marko
Old Aug 17, 2012 | 10:07 PM
m4byfun's Avatar
you could use a key that is programmed to car and install it under the cover around the steering colume and tape it to the key barrel and then you can use a cut key without have to pay to have all the other key programmed and you will always have a extra key if needed. cost saving and then you can also us a key that does not have a chip in it to save on key cost.
Old Aug 18, 2012 | 08:09 AM
Marko,
You can program a Remote/Fob as a DIY procedure but the Key can only be coded to the car by a Jaguar Dealer or someone with the Jaguar WDS (Worldwide Diagnostic System).
Not many independents in the UK have this equipment but David Marks Garages in Nottingham is quite close to you and may be able to help if you want to avoid the Dealer network.
Old Aug 19, 2012 | 09:07 AM
markocosic's Avatar
Thanks Graham. I'll ask around a few dealers and David Marks and see who wants the business. :-)
Old Aug 19, 2012 | 10:20 AM
Mark,
When you get the chance, let's see a pic of the 'X308 Phateon (4 door Daimler Corsica replica based on 1997 XJ8 4.0'.
Old Aug 20, 2012 | 04:21 AM
markocosic's Avatar
Work in progress:
About SpeedView Displays (UK) Ltd | SpeedView
dsnyder586
Dec 29, 2024 07:39 PM
peterg19
Feb 10, 2023 09:02 PM
XJsc-guy
Nov 23, 2015 01:56 PM
Rick Michael
Sep 6, 2015 06:53 PM
My Pham
Sep 4, 2015 03:37 PM
