PS Pump Seal Drag
Old Dec 13, 2017 | 04:00 PM
nilanium's Avatar
Default PS Pump Seal Drag
The PS pump in my car has been making noise for a while, and had a tick that could be felt turning it by hand, so I recently sourced a junkyard PS pump from another x308. It seems to spin smoothly, but I did notice it has a good bit of what feels like seal drag when spinning it on the bench by hand (no fluid in the pump). It makes sense that it would drag in my head since they are compressing up to the ksi range, but I haven't worked with these enough to know from experience. Is a moderate amount of seal drag expected when spinning a dry (good) PS pump?
I also noticed there are seal kits on rockauto, is it worth grabbing one of those to rebuild the pump while it's out? Or are those only for aftermarket pumps, as the FSM says the pump is non rebuildable?
Old Dec 13, 2017 | 04:47 PM
Highhorse's Avatar
I would take non rebuildable with a grain of salt, like the non-serviceable transmissions. A power steering system is simply a hydraulic system and every hydraulic system I've seen is capable of a rebuild. Whether your replacing hoses (like I just did on my Vette) and/or doing seals, its just a matter of if the parts are available.
Old Dec 13, 2017 | 04:54 PM
motorcarman's Avatar
TSBs have so much info that many are not reading!!!!!!
Might be the problem but worth looking into.
bob
File Type: pdf
Old Dec 13, 2017 | 06:32 PM
Lady Penelope's Avatar
Just a drain / refill several times can resolve some pump issues as the 20 year old fluid breaks down and is just as important as the metal parts . Just did that on a different car that sounded like a bearing and now silent . Cavitation is one of the sounds not often thought of but a phenomena in pump physics
Old Dec 13, 2017 | 10:51 PM
nilanium's Avatar
Cracked the "new" pump open to take a look - doesn't seem like there's much serviceable bits in there, not without some beefy pullers since both sides are pressed onto the axle. The only easy part would be the main pump body seal, hopefully I'll luck out and that one survived the reassembly, since those aren't available online that I've seen.
It's a pretty neat design these PS pumps have for compression, I didn't know about it before. I'll be sure to flush the fluid when I put this one in, but having seen this one, I'm wondering if the tick I felt on the "old" one when rotating by hand is one of those roller vanes sticking.
This pump felt fine to spin when the back was off, so I'm guessing the "drag" feeling is normal.
Old Dec 13, 2017 | 11:17 PM
Atlantic Enterprises makes the pump Jaguar # MJA8111BG ( Atl. # 3517V ) To VIN (F05724) and Jaguar # MJA8111BH ( Atl. # 3518V ) From VIN (F05725)
http://www.aaesteering.com/
http://www.aaesteering.com/AAE-COMPLETE-CATALOG%20.pdf See page 23
http://www.aaesteering.com/TROUBLESHOOTINGGUIDE.jpg
Might find the seal through Ford Lincoln LS sources
https://jec.org.uk/forums/viewtopic.php?t=9127
eurolat
Feb 12, 2018 03:35 AM
gthawk1
Jun 10, 2014 06:25 AM
Jeh
XJ40 ( XJ81 )
Jun 2, 2012 10:07 AM
Chaz17
May 6, 2012 10:09 PM
AntixSD
Apr 3, 2010 07:40 AM
