Pulley Upgrades for XJRs
Old Aug 13, 2025 | 06:26 AM
Hooli's Avatar
Default Pulley Upgrades for XJRs
I believe the best pulley to upgrade for more grunt is the lower pulley & as my car still needs the chains doing I plan to get both done at the same time.
However I can't find a definitive answer on what pulley to fit, just that it's off a 4.2 But some things I've read say the 4.2 LR version of the engine has the smaller 4.0 pulley. So can anyone tell me exactly which pulley I should be looking to buy ready for the job?
Thanks,
Old Aug 13, 2025 | 07:48 AM
Quadcammer's Avatar
i used the x350 XJR pulley, which fit fine. That said, its only a little bit larger, so you won't get much of an improvement. Since I have an upper pulley, i didn't want to go nuts on the lower. If you plan to keep the upper stock, I would go with the aftermarket ones.
Old Aug 13, 2025 | 09:35 AM
Hooli's Avatar
Thanks, yeah I was going to stay standard at the top to keep things simple.
Old Aug 21, 2025 | 02:31 PM
vincent661983's Avatar
Power House UK
Old Aug 22, 2025 | 04:55 AM
Sean B's Avatar
I've got a Paramount lower pulley I would part with. Thing is you'll need the harmonic balancer machining to fit it. Addicted2Boost has fitted an XFR lower, maybe shoot a PM for diameter. It should go up an inch.
There's a belt you'll need for the extra length.
I found it just brings the torque curve in earlier, no boost raised, it doesn't need it. If an AJ26 motor get the ML steel 4.2 head gaskets fitted, maybe uprated IC pump (Bosch 050) and IC rad, oh and hoses.
Old Aug 26, 2025 | 08:58 AM
Hooli's Avatar
Cheers for the info chaps. I'll have to have a good look at the options & decide where to go. I have thought an uprated IC pump is a good idea, I've still got suspicions about mine being tired. It blew several fuses when I got the car & I still seem to lose MPG once it gets hot on a long run, nothing like without the pump but a more mild version of the same thing.
I won't be doing the work, I can't manage such things any more without spending days in pain from a dodgy back & I've only got a rough uneven drive to do stuff on.
Old Aug 26, 2025 | 10:55 AM
Hooli's Avatar
Any idea what you'd want for it? I've just spoken to them & it's the same increase as the Powerhouse UK one, so makes sense to buy yours & save a few quid. The garage who will be doing it know old Jags so are aware of the machining requirement.
Looks like paramount are £20 cheaper for the pump, at £155. I'll have a google for the details you gave to see if it's cheaper from another source though.
Old Sep 13, 2025 | 08:02 AM
Hooli's Avatar
To kick this thread off again, I've been looking at this advert for the pulley & belt https://ebay.us/m/iafuNJ but unsure about the damper my car has. The advert shows pics of the difference but I can't tell looking at the car, does it have to be disassembled before you can see which sort of damper is fitted?
Old Sep 17, 2025 | 12:53 PM
Quadcammer's Avatar
should be able to see the difference in the front with a mirror.
My 99 had the "does fit" style
Old Sep 18, 2025 | 05:06 PM
Hooli's Avatar
I tried that & couldn't tell, guess I'll find out as this arrived from Sean B today.
I'll have to get the uprated pump ordered & then book it in for all the work I want done. Should be ready just in time for cold slippery roads I can't drive it fast on anyway!
Old Sep 18, 2025 | 06:26 PM
Addicted2boost's Avatar
If I had to guess what year lower balancers are compatible, I’m guessing the AJ26S engines.
Z07Brandon
Sep 8, 2020 03:07 AM
James Hunt
General Tech Help
19
May 12, 2020 12:05 PM
XxSlowpokexX
Jul 18, 2014 04:14 PM
XxSlowpokexX
Jul 17, 2014 10:42 AM
