Quicky question 1999 XJ8 coolant line
Old May 1, 2012 | 11:08 AM
kenncl's Avatar
Default Quicky question 1999 XJ8 coolant line
Hi Guys,
I am replacing the coolant recovery line between the reservoir and the radiator but I have never seen connections like theses before and do no want to do any damage forcing them. What is the trick to removing and replacing them?
Thanks Guys
Ken
Old May 1, 2012 | 11:53 AM
mzs_biteme's Avatar
The whole line maybe quite brittle, so be very careful.
When working on mine, the line cracked right behind the connector (thankfully) on the coolant reservoir, , so I was able to salvage the connectors on both ends (cut off the other end right at the connector) and just use a standard rubber hose to connect them back up.
Old May 1, 2012 | 01:11 PM
motorcarman's Avatar
Here are 2 TSBs that will answer your questions.
bob gauff
Old May 2, 2012 | 03:41 PM
kenncl's Avatar
Default Thanks
It was a breeze after I knew how it worked. Would have shot myself if I broke the new one.
Again, thanks for your help.
OkieTim
Sep 8, 2015 04:48 PM
Xkr x100
Sep 6, 2015 08:50 AM
Bcrary3
Sep 3, 2015 03:48 PM
OkieTim
Sep 2, 2015 12:48 PM
