Radio canot lock in a station.
Old May 31, 2017 | 10:46 PM
Roaar's Avatar
Default Radio canot lock in a station.
Radio canot lock in a station. It keeps searching and searching for a station signal. All I hear is static. Also the CD player does not work. The radio reads: no CD. And the antenna has trouble going down. Usually stops about 3/4 of the way down. Are these related problems? Any advice or suggestions on any of these problems would be most appreciated. What good is a convertible without tunes?
Old May 31, 2017 | 11:47 PM
vdpnyc's Avatar
Convertible?? You are posting in the wrong forum.
If your antenna does not go up normally and you cannot get FM stations it is likely the same problem - your antenna needs to be repaired/replaced.
Old Jun 1, 2017 | 06:20 AM
Highhorse's Avatar
Welcome Roaar, please introduce in the New Members Forum and tell us about yourself ...https://www.jaguarforums.com/forum/n...-intro-must-5/
Like vdpnyc said...Convertible? ...not on an X308, I think you want the XK forum. Lets see if we can get a mod to move ya there...
For your issue, it sounds like something disconnected on the CD unit. Whether it be by a connector itself or a cold solder joint let go or your internal neoprene line broke and thus the mast won't go back down. In either case, we need to know the type of stereo you have. Is it the base model, Alpine w/amp...
Old Jun 1, 2017 | 07:48 PM
Don B's Avatar
Hi Roarr,
Welcome to the Jaguar Forums! It's great to have you with us.
As has already been mentioned, we really have to know the year and model of your car in order to provide accurate replies. Once you let us know, I'll move this thread to the correct forum.
Also, as Highhorse mentioned, please visit the https://www.jaguarforums.com/forum/n...-intro-must-5/ and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
sorapp
F-Pace (X761) / C-X17
Mar 12, 2017 10:50 AM
901
XF (X260)
Dec 28, 2016 09:56 AM
EFrazen
XJ40 ( XJ81 )
Apr 7, 2014 11:49 PM
hypoluxo
Mar 30, 2013 02:21 AM
stucooke
Dec 7, 2010 11:52 PM
