Rear A/C
Old Jul 30, 2009 | 04:12 PM
stran0020's Avatar
Default Rear A/C
I have a 2000 VDP the rear A/C vents run very very weak even when the fan is on high! you can barely feel any air coming out of the vents. Is this normal? or do i have a malfunction somewhere? If i put the vents up front in the closed position thats the only time you would be able to tell the A/C is on in the rear. Other then that the A/C seems to be working fine, I just feel bad when i have people in the back seat.
Is it normal to have weak A/C in the rear? My brother has a 2005 300C and his rear A/C blows just as hard as the front! help! thanks in advance
Old Jul 30, 2009 | 07:20 PM
Sarc's Avatar
@stran
My '00 XJR is the same. Maybe others will chime in and give us more data points. When I've had the centre console in pieces for various reasons in the past I've noticed the feeds into the rear air vents are very very narrow, so maybe by design you're never going to be able to get a lot of air out of them.
I wonder if setting the air flow selector to the floor would help cool the back down as there are floor vents under the front seats facing backwards which look a lot bigger than the face vents. I'll try an experiment on the way home and report back.
The best cars I've seen for rear ventilation are Volvos (S80 I think) which have air vents in the pillars which you can direct straight into your face, enough to give you brain freeze.
Old Jul 31, 2009 | 12:57 PM
DavidB's Avatar
Same here--the airflow from my rear a/c outlets is very weak. SARC is right, the main problem is that the ducts that feed the rear outlets are much smaller and restrictive than those that feed the front.
TTYL
David
Old Jul 31, 2009 | 11:48 PM
stran0020's Avatar
Anyone know what would be the best way to address the problem?
Old Aug 1, 2009 | 12:44 AM
Sarc's Avatar
Well, I tried setting the flow to floor and sitting in the back but the vents under the front seats that point backwards didn't do anything, so I don't even know if they are supposed to be vents or not.
The best way I've found to cool the people in the back is have the middle vents on either side of the clock set so they are pointing straight back (and not angled at the front passenger and driver) and have the blower on higher than you would normally when you were only in the car yourself.
I've had a few passengers comment that they thought the A/C in the Jag was "very good" so I guess it's all relative. For sure the front may cool down a little faster than the back but once the A/C has moved the air around the cabin a few times it's pretty even. Personally I don't like having air blowing in my face anyway as I get a headache.
Old Aug 1, 2009 | 12:23 PM
stran0020's Avatar
Owning a 10-year old car I would like to bring it up to date as much as possible while still keeping the sexy XJ8 body!. Nice A/C, H.I.D lights, Power fold mirrors, in dash GPS, Ipod dock. These are things I would like to do throughout owning the Jag.
What else can you guys think of to bring our "old mans" car more up to date?
Anyone know what kind of custom work could be done to the A/C, I want my Jag to be colder then a freezer! (live in a desert)
Old Aug 2, 2009 | 11:52 AM
SuperSport's Avatar
Yes, I guess it is all relative. My '99 Black on Black gets VERY hot here in the Summer (99-110 Degrees), but Cools down quickly, back seat and all. I also aim the center vents to the back until it's cooled down as I do like the air in my face.
The back vents are only good for maintaining the temp after the front vents have cooled the cabin down.
Old Aug 4, 2009 | 06:32 AM
hrand1987's Avatar
Originally Posted by stran0020
Owning a 10-year old car I would like to bring it up to date as much as possible while still keeping the sexy XJ8 body!. Nice A/C, H.I.D lights, Power fold mirrors, in dash GPS, Ipod dock....
Everything has been done there except updating the A/C. A tech on here has retrofitted HID lights should be able to find a how to by an advanced search, In england our cars have power fold mirrors so you can find a kit and install it (I think it was around $600 tho) perform a search here or try other jaguar xj8 forums, link here for indash gps (pics links are broken but you can try emailing the poster and find out more) or maybe you can try fitting the xk8 color navigation kit (my 03 xjr has factory nav but it is black and white), and there is a somewhat current thread on ipod connectivity.
Further note, have had 3 x308 and 1 x300 in the family, all A/C rear vents are poor. I find it best to channel all the air from the center vents by the clock to the back seat as well.
Old Aug 4, 2009 | 10:07 AM
stran0020's Avatar
Can you direct me to the other forums?? I've been searching all over for other forums dedicated to the xj8 but have found nothing good other then jaglovers and this forum!! If you know of any good ones please post them up! Thanks
Old Jun 15, 2010 | 12:55 PM
judas74205's Avatar
So I was about to post something about this low rear Vent issue but I noticed somone already have. Any Up to date on this issue? Anyone?
Old Jun 30, 2010 | 01:00 AM
chaseatl's Avatar
Default rear air vents
My rear air vents on my 1999 XJR blow little air to say the least.
Old Jun 30, 2010 | 02:29 PM
QuadManiac's Avatar
If you're determined to improve the rear A/C flow, and if you don't mind losing some of the center console storage space, you could add a small, squirrel cage blower in the console, with some interesting duct mods, to assist in getting more air flow through that skinny duct that exists under the console storage bin. I can see how it could be done... not interested in doing it myself, lol.
Old Jun 30, 2010 | 07:31 PM
csh1259's Avatar
Default Rear Air
I am new to this forum as well as a new Jag owner. I have a 1998 XJ8L and agree that the rear air flow is limited. Overall the AC does a great job in cooling the car even in very warm weather.
Old Jul 1, 2010 | 08:59 AM
Virgo1979's Avatar
I have a 00 xjr and the a/c blows the same front and back....even if your car a/c in the back doesn't blow hard like the front it's better then a/c not working @ all....but your car looks great btw
H20boy
Dec 24, 2024 03:23 PM
jehart49
Sep 12, 2015 05:36 PM
Saturbo
Sep 8, 2015 07:35 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
