rear door passenger side
Old Nov 26, 2019 | 10:24 AM
philip s's Avatar
Default rear door passenger side
the rear passenger door will lock using the key fob but will not unlock, all other functions are ok, i have a 2003 xj6 v6 se
Old Nov 26, 2019 | 10:27 AM
King Charles's Avatar
Not sure how or if the child lock figures into this but give it a try located on the door seal/edge.
Old Nov 26, 2019 | 03:04 PM
Highhorse's Avatar
Possibly sounds like the mechanism brushes are failing....the pulling action is easier than the pushing. It could be gunked also, simply spraying the cable (clean any noticeable clutter) and latching mechanism with some dry lube silicone spray (yeah, sounds like an oxymoron) may cure the issue also. Function the latch, put a screw driver in it to engage it, spray again, retract,...spray, ...engage, ....spray ...until it operates smoothly. If it doesn't after that, back to the mechanism failing.
rosuab
Jul 2, 2018 10:59 AM
YellowAndBlue71
Jan 31, 2017 12:30 AM
steely
Jul 25, 2013 05:39 AM
dwclapp
Oct 24, 2011 09:10 PM
jagmarine
Feb 7, 2009 05:54 PM
