Rear End Fluid
Old May 29, 2012 | 02:31 PM
Rlover's Avatar
Default Rear End Fluid
So tried to change the rear end fluid in a 98 XJR this past weekend. I have no socket that fits into the drain fitting that can get infront of the support bar.
Does anyone know of what fitting and where I can buy it? Seems silly to spend 3 hours and then replacing bushings etc to take off a drain plug. Hoping that a Tech knows what to do? If not the supporting for the rear end and sway bar would have to come out, uhhhhhhhhhhg.;
Best
Old May 29, 2012 | 05:04 PM
plums's Avatar
There is a thread about this.
But, you can use one of those 1/2" drive spinner adapters. Then use a regular wrench to turn the wrench flats on the adapter.
Or, a 1/2" drive wobble extension.
The correct length is in one of those threads.
GordoCatCar
Jan 2, 2017 01:10 PM
Thang Nguyen
Oct 12, 2015 01:25 AM
RaceDiagnostics
Sep 7, 2015 07:28 AM
XKR-NC
Sep 4, 2015 08:23 AM
obwoodie
Sep 3, 2015 07:45 PM
