Rear hub bearing replacement write-up
Old Dec 12, 2023 | 05:49 AM
Mikemaxwell's Avatar
Default Are mine too far gone?
Hi, my mechanic spotted that these bearings were gone on my XJ81. They've been goosed for a long time and the HUB has worn against the wishbone.
will this be cosmetic or do I need a whole new one?
Old Dec 12, 2023 | 04:14 PM
Highhorse's Avatar
Your talking about two metal products rubbing against each other for quite a time. I'd suggest you go to a junkyard and do some comparing with a micrometer and sourcing possible replacement parts while there. I'd also watch the video KC provided in post #15 just to get an idea of the parts in that area that will also wear and may be gone. Check https://www.car-part.com/ for the parts and/or full on assemblies as well...there are other sources for yards.
Please provide go into your User CP and add your location, model and year so we can direct you more efficiently. NA and EU models each have certain nuances, so this is helpful to you...cheers.
Old Dec 12, 2023 | 05:46 PM
Default Thanks
I suspected this might be the case and have found replacement parts just incase. I was hoping that it would just be cosmetic damage and wouldn't affect the integrity of the parts too much.
cheers
Old Dec 14, 2023 | 07:17 AM
Default Part number
My car is a 1994 XJ81 (XJ40 6.0 V12)
For the rear hub carrier I've seen 2 part numbers
CAC9483P
and
CCC3985
Any ideas of the difference, and which one I'm likely to need?
Thanks in advance
Old Dec 15, 2023 | 08:45 PM
Highhorse's Avatar
Have you looked them up for comparison with your pics?
Old Dec 16, 2023 | 04:23 AM
Default Hub numbers
Yeah, mine are the ccc3598.
they aren't available anywhere.
I was hoping that it was an insignificant change and that the 2 part numbers were interchangeable as the other type, "CAC9483P" are available
They look the same to me, and are advertised as fitting an XJ40
​​​​but I know it doesn't work quite like that.
Old Dec 18, 2023 | 01:39 AM
Highhorse's Avatar
Well, I have to say, this is the wrong forum for your issue, I should had paid more attention to 1994. The XJ40 is... https://www.jaguarforums.com/forum/xj40-xj81-25/ ...those folks will have more direct info and resources for you. Also, don't forget to check in the Marketplace, top task bar, 5th option from the left for member items for sale... https://www.jaguarforums.com/forum/p...classifieds-9/
Always check the Sticky's at the top of each forum for possible solutions other members have posted specific to your issue.
This should help you a bit more as well... https://parts.jaguarlandroverclassic.../brand/jaguar/
...and... https://parts.jaguarlandroverclassic.../brand/jaguar/
GregChap
Mark V - X 420G
Oct 9, 2024 08:48 AM
max224
Sep 30, 2022 05:09 PM
MiamiFtype
Jan 12, 2019 09:27 AM
NiteriderSC
Sep 2, 2016 03:14 PM
