rear seat removal.....I've used the search!
Old Aug 4, 2009 | 04:55 PM
Sean B's Avatar
Default rear seat removal.....I've used the search!
Car is 2001 XJR - I'm stripping it, and need to get the rear sets out, got the bottom out, located the 3 torx to drop the seatbelts, now need to get the upright out.
I've used the search, but no pointers to how the back is held.
Thanks for any suggestions
________
Harley-Davidson Model BA
Old Aug 4, 2009 | 05:07 PM
JagtechOhio's Avatar
It slides up, when everything is free first. Four screws at the bottom. BUT...
You have to remove the plastic seat belt trim covers at the top of the rear seat squab first, and the plastic roller guide beneath. Times three. Use two pocket screw drivers on the trim, one to depress the plastic retaining clip on the top as you gently pry the cover up from underneath it. When both of the two retaining clips are released, carefully remove the cover straight up or you will break off the two locating tabs on the rear side. Then pry up the white plastic roller guide to release that two.
Unbolt the three rear seat shoulder belts at the bottom anchor point. Then lift up really hard on the rear seat squab to disengage it ai the top. Sometimes you have to squirt some Armor All or whatever into the seam, and try to spread it apart with your fingers or other soft tool: heat bakes the rear parcel shelf cover and the rear seat squab, and sometimes they are pretty well stuck together.
Raise the squab above the shoulder belt reels, feed the belts through the cutout in the seat, and it's free of the car.
Old Aug 4, 2009 | 05:42 PM
Sean B's Avatar
Default Brew time....
spot on, cheers JTO
________
buy air one vaporizer
Old Aug 4, 2009 | 06:08 PM
Have a blast, you're welcomed. Are you adding something to your car?
Old Sep 5, 2009 | 01:04 PM
blkjag's Avatar
I am replacing my fuel pump can you tell me how to get the tank ont? I disconnected the attachments (the 2 straps). Do I have to remove the back seat? I don.t have a book but anything you can provide to help would be greatly appreciated.
R,
Blkjag
Old Sep 5, 2009 | 01:08 PM
Blk, I don't know what model you have, but taking out the back seat does not get you anywhere. You're probably hung up on the outlet and return lines that attach to the tank, under the car.
Old Sep 5, 2009 | 01:17 PM
blkjag's Avatar
Default fuel tank
I am sorry, I have an 1998 xj8 and i am trying to replace the fuel pump. I was thinking that if I remove the 2 strap that it would just pull out. Also how do I drain the tank?
R,
blkjag
dsnyder586
Dec 29, 2024 07:39 PM
JagBrian
Aug 18, 2019 05:07 PM
GordoCatCar
Jan 2, 2017 01:10 PM
jdzubas
Oct 4, 2015 09:14 AM
Dallas XK8
Sep 3, 2015 12:17 PM
