Rear Shock Isolators - which to buy?
Old Mar 2, 2025 | 11:54 AM
mike32966's Avatar
Default Rear Shock Isolators - which to buy?
The rear of my US spec 2000 XJR is running about 42mm (1.65") low. I pulled the rear springs to check what was going on and it looks like the KYB rear isolators (MMD3565AA) have collapsed. They were installed a little over 3 years ago when I replaced the shocks.
The newer KYBs are now black while mine are the OEM yellow so maybe they've changed the materials but I'm still reluctant to go with KYB again. I see original Jaguar parts available but presumably they've been sitting on a shelf for 20 years so wondering if they are still good. The foam seems to deteriorate with age more than use. Rockauto is listing DEA / Marmon and Delphi alternatives for half the price of the Jag ones.
Anyone had good experience with either original Jag or other manufacturers?
Old Mar 2, 2025 | 02:58 PM
Addicted2boost's Avatar
Jaguar oem only for those rear upper shock mounts. 3 upper on each side.
kylexj6
Aug 26, 2023 01:37 AM
Devo
Feb 6, 2023 03:02 AM
Mr rx-7 tt
Dec 13, 2021 05:05 PM
impster
XJ40 ( XJ81 )
Jan 12, 2021 08:51 AM
trymes
Mar 26, 2013 09:45 AM
