rear speakers
Old May 19, 2018 | 12:57 AM
burljoseph's Avatar
Default rear speakers
rear speakers dont work.
how to enable them?
Old May 19, 2018 | 01:04 AM
blgdave's Avatar
Really could be anything. Head unit, amp, speakers themselves, or just a slipped cable from any of these areas.
Use a AA battery connected to a couple of wires and work your way through connectors touching the + and - wires to each. You will hear a crackle noise in teh speaker that confirms the connection. Then just work backwards towards the head unit.
You could be a while getting at all the connectors though!
Old May 19, 2018 | 06:00 PM
Lady Penelope's Avatar
With a 2008 XJ you have a X358 series with an aluminum body .
Suggest posting in that area for people with that design .
In the mean time Blgdave is correct in the use of a 9 volt battery and the scratch test starting with the amplifier connections .
I'll look up a wiring diagram for you stereo system if available . Below :
[url]http://www.jagrepair.com/images/Electrical/XJElectrical/2008%20MY%20XJ%20Electrical%20Guide.pdf /url] See page 154 but your premium system is on page 157
If you need a part one X358 came into the local salvage yard .
Old May 19, 2018 | 07:32 PM
blgdave's Avatar
I would not use a 9v battery. AA battery is just 1.5V and works just fine
Old May 19, 2018 | 08:05 PM
There may be a stereo mode selector not switched correct like say a telephone mode . , That could be easier to check the owners manual then chasing wires .
Old May 19, 2018 | 08:19 PM
King Charles's Avatar
Also rear speakers fade/balanced out option.
yardbird
Dec 27, 2023 03:05 PM
FerrariGuy
May 24, 2017 02:40 AM
MiniFarm
Oct 21, 2016 02:50 AM
hirev
Oct 16, 2016 08:49 PM
seeyouincourt28
Feb 20, 2007 12:03 PM
