Rear Wheel Hub
Old Oct 29, 2014 | 12:12 PM
Heliwilly's Avatar
Default Rear Wheel Hub
I am getting a noise from one of the rear wheel bearings. I have a complete used unit for the side I want to replace. The problem is that the hub on the car has long studs to suit the "Celtic" alloys that are fitted, and the spare unit has short studs that appear to be a permanent fit.
I assume that when I fit the refurbished hub carrier unit, I will have to put the long studded wheel hub into the refurbished hub.
I had originally thought the wheel studs were screw-in. Guess I was wrong. Any thoughts?? Thanks Bill W.
Old Oct 29, 2014 | 12:43 PM
Bumbazor's Avatar
From experience they are a tight press fit, so if you really wanted you could press them out and swap round, though for the long ones it could be tricky without separating the hub from the knuckle. Short studs can be removed in place.
I don't know if that is particularly recommended though, but it certainly is possible.
When I removed the front hubs on my car I had to remove the studs for what I was doing, rears didn't need it but I think they're the same fit type.
New studs are available anyway so I think it would be ok.
Old Oct 30, 2014 | 03:07 PM
Heliwilly's Avatar
I will be sorting the rear hub out next week. Could someone tell me the size of socket for the rear hub nut. Also the rotor splash guard is held on by 2 different size of TORX bolts. What size are these? Thanks Bill W.
dsnyder586
Dec 29, 2024 07:39 PM
PMKimpton
Aug 3, 2019 08:22 PM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
Joey T
Sep 3, 2015 05:31 PM
innzane
Sep 2, 2015 10:08 AM
