Rebuilding a lowered x308 ...
Old Jun 27, 2019 | 05:34 AM
ericjansen's Avatar
Default Rebuilding a lowered x308 ...
I was asked to order parts to bring a Japan imported lowered Daimler back to its original ride height.
Problem is; I am making the parts list remotely, as I did not see the car, and she is 400km away.
Am I forgetting something?
- front & rear springs (Daimler LWB / probably used)
- front and rear shocks (CATS or traditional - depending owner's choice)
- front uppers (CATS or traditional - depending owner's choice)
- front & rear packers in correct thickness
- Rear donuts
- Camber parts (depending check - front arm or bolt / rear spacer??)
Enclosed the only recent pic of the car, to me it seems its got quite some camber, so they probably did not modify the parts related to that.
Old Jun 27, 2019 | 07:27 PM
Z07Brandon's Avatar
Man that looks so good.
Old Jun 29, 2019 | 12:01 PM
Highhorse's Avatar
Be prepared, the rear camber may need a shim kit?
Old Jun 29, 2019 | 07:54 PM
ericjansen's Avatar
Ha, as mentioned, we will reverse it back to the original height,it is lowered right now, and the owner does not want it.
Hence my question on the parts ...
And to me, it looks it's got plenty of camber in the lowered position, so they probably did not touch the shims.
What do you think judging the pic?
Old Jun 29, 2019 | 08:00 PM
Carnival Kid's Avatar
Looks PFU, if mine looked like that I would be concerned!
Old Jun 29, 2019 | 08:20 PM
ericjansen's Avatar
And "PFU" means ....?
Old Jun 29, 2019 | 08:28 PM
ericjansen's Avatar
I received some pics of the underside just now, seems they indeed only changed out the springs (yellow, no brand determined yet).
I was contemplating to use them on my car, but decided against it.
It will be the end of practical use of my car, will not be able to drive it out of my B2 parking without getting beached.
Old Jun 29, 2019 | 09:25 PM
Too risque to post the link, Google is your friend. (Supersuckers)
Old Jun 30, 2019 | 06:18 AM
Blown Income's Avatar
Judging from the photos and the angle of the springs along with the rust spots localized in one general area, i would say these springs have been “lowered” via torch. Block the car to the desired ride height and heat the springs up until they collapse onto the blocks. Extremely bad way to lower a vehicle.
Old Jun 30, 2019 | 08:36 AM
ericjansen's Avatar
Just confirms that I am indeed living under a rock ... with just my cars and bikes ...
jchou
Sep 13, 2013 09:58 PM
michaem101
Jun 5, 2010 10:43 PM
Jagbuff
Oct 9, 2009 09:32 AM
Rlover
Apr 12, 2009 04:21 PM
Brake buster
Mar 31, 2008 03:47 PM
