Red oil drips
Old Oct 8, 2013 | 04:00 PM
Len Apcar's Avatar
Default Red oil drips
So I am occasionally seeing small drops of red oil or fluid underneath the car when it is parked overnight.
The drops seem to be in the center/right side of the engine compartment back of the front passenger-side tire.
Is this possibly power steering fluid and is there a hose in that neighborhood? (I know the pump is on the left)
Would transmission fluid leak on the center right side near the wheel? Seems unlikely?
Any other source of red fluid in the center, right-rear side of the engine area?
In short, what is everyone's best guess as to where the fluid may be coming from and since it is only every other day or so is can it wait a while?
No other problems are evident in steering, shifting, etc.
Thanks.
Old Oct 8, 2013 | 05:12 PM
It sounds as if the quantity is insufficient to be a concern but is more of a nuisance.
Leaked fluid can run along pipes before it drops to the ground and can also be blown away from the source whilst driving.
Here's the steering system schematic:
You're going to have to get underneath to check for possible sources. Unless there anything loose or split (unlikely with it only being a small leak), cleaning off will probably be necessary to pinpoint it.
Old Oct 8, 2013 | 07:22 PM
RJ237's Avatar
Unless you have had the transmission fluid changed it can only be power steering. The factory transmission fluid is gold, both in color and price.
aholbro1
Dec 29, 2024 06:46 PM
99xk8guy
May 28, 2024 09:36 PM
Jandreu
Jun 30, 2022 03:10 PM
kelliott
May 31, 2022 05:26 PM
Saturbo
Sep 8, 2015 07:35 PM
