Remote key fob malfunction
Old Mar 14, 2014 | 09:34 AM
Takeo's Avatar
Unhappy Remote key fob malfunction
Hi,
My 2001 x 308 has the following problem:
Pressing the "Door Open" button on the remote keyfob works perfectly.
Closing with the remote, however, only works occasionally.
To close, I have to hold the remote in all sorts of awkward positions, at different distances, and then there is a chance that it works.
Now, the "Close" function stopped working altogether. I close using the key but can open using the remote.
Cannot be the battery, since the "Open" function works normally.
Has anyone got an idea how to repair this ?
Thank you.
Takeo.
Old Mar 14, 2014 | 09:52 AM
WhiteXKR's Avatar
Open it up and give it a thorough clean. See attached.
Old Mar 14, 2014 | 10:41 AM
Takeo I've moved your post to the X308 section, as all fobs are not equal and you'll get more specific answers here.
Old Mar 15, 2014 | 11:22 AM
Takeo's Avatar
Unhappy Key fob, remote.
Hi guys,
Ok, I followed the instructions for cleaning with Isopropyl Alcohol.
But my key fob interior looks different, instead of having 4 printed circuit contact points, it has something that looks like 4 round, slightly protruding switches.
Tried again, unlock works perfectly at virtually any distance. Lock does not work at all. So I lock my cat now with the key.
Any other suggestions ?
Thanks,
Takeo.
Old Mar 15, 2014 | 11:56 AM
WhiteXKR's Avatar
Originally Posted by Takeo
Hi guys,
Thanks,
Takeo.
OK, you have the later version fob with the mechanical switches. The switches are available on ebay: Jaguar s s Type XJ8 XK8 XJR XKR Switch Button Repair Remote Key Fob Controller | eBay
If there is a local electronics repair shop nearby they should be able to easily replace it. Otherwise replacement fobs are also available on ebay and are not too costly.
Old Mar 16, 2014 | 04:51 AM
Takeo's Avatar
Smile Switches
Thank you,
I bought a pair of switches on e-bay as you suggested.
Will keep you posted.
Takeo.
Old Mar 16, 2014 | 08:18 AM
Takeo's Avatar
Question Another question
Ok, when I get the new witches, I will replace just one.
Would you know the exact procedure of how to take one switch out and replace it.
Is it clipped, screwed ? Any soldering ?
No repair shops around here since I live in the middle of nowhere in South-West France (16320 ROUGNAC, pop. 400).
What about a drop of WD 40 or diesel oil on the faulty switch ?
One possibility is that the switch button is just stuck.
When I check it from close, under a magnifying glass, pushing on the switch does not show any in or out movement.
Thanks,
Takeo.
Old Mar 16, 2014 | 09:22 AM
WhiteXKR's Avatar
They are surface mount soldered. This is a bit tricky to repair and easy to damage the circuit board (that is why I suggested a shop) unless you have experience with this type of thing.
At a minimum you need a very small soldering iron (15 Watts) and a handheld plunger type desoldering tool, and some very fine 63/37 flux core solder.
Old Apr 24, 2015 | 04:59 AM
Nigel Adelaide's Avatar
Default XJ8 (X308) remote key fob
Hi having just bought my 2000 XJ8, the seller had two remotes but neither worked properly .He said batteries flat but was not the problem and new batteries no help. Tested old batteries each still 3 volts .Then took the electronic board out of its rubber surround for each remote and cleaned and dried the contacts under the buttons thoroughly with a tissue and Methylated Spirits as well as the connection for the batteries and the underneath of the rubber buttons. Installed the original two 3 volt CR2016 batteries positive side down as said on the black cover now both remotes work perfectly.
3lvis
Oct 1, 2015 01:56 PM
Swagguar
Sep 30, 2015 01:34 PM
Jzar
Sep 27, 2015 02:55 PM
zdrapec
Sep 25, 2015 05:49 AM
