Removing thermostat will stop coolant leak temporarily?
Old Nov 11, 2024 | 09:01 PM
Silverjag0's Avatar
Default Removing thermostat will stop coolant leak temporarily?
Okay so 2 days ago I had low coolant on the dash checked here n there I found that the front right side of the tank is leaking i added epoxy to stop the leak it did work but I saw again tiny leak in the epoxy itself it spray coolant through the grill now I want to add more epoxy to stop that leak
What I want to know is if I removed the thermostat will that lower the pressure in the cooling system?
Less pressure no leak ?
Till I find good used radiator and replace it
Ken D
May 10, 2024 03:28 PM
Adventurous x
Feb 7, 2023 11:14 AM
mpasiuk
24
Mar 14, 2022 10:12 PM
xtypejag502
Jun 16, 2016 01:09 AM
vettegood
Nov 24, 2012 10:31 AM
