Replaced trans cable, still having same issue (DLS?)
Old Apr 14, 2016 | 07:34 PM
vsol's Avatar
well I tinkered with it again last night. The DLS adjustment is pretty sensitive when doing it in neutral ie there is only a small contact point (3mm?) For the dls to read neutral. There is about twice the amount of play when mounting the DLS than the length of the contact point for neutral inside the switch. I put it together very carefully to ensure it wwas staying in the neutral part on the dls. Put it all back together thinking it was going to work and I still had no illumination for the gear selected or a shifting trans. Cel still on. I jiggled some wires and did a few hard resets and then cleared the cel on my phone app via Bluetooth. Then the gear illumination turned red and lit up for some reason !
It was giving secondary faults too so I cleared those too. Car is running and driving fine now. it is most certainly an electrical connection issue. I ordered a whole new shift assembly because I'm sure the problem is just temporarily fixed. But at least I can dive the big cat now
Originally Posted by Highhorse
For any codes regarding Jaguar, be sure to put Jaguar code P0705 or whatever code because a lot of standard OBDII codes do not cross reference with Jag exactly and may mislead you.
Thank you sir
Old Apr 15, 2016 | 07:11 AM
Highhorse's Avatar
That is good news to a point and you were smart to order the other for replacement. Now at least you are pretty sure of your issue and hopefully the new piece will cure it. Plus you get to drive her...
jagpaw
Jun 12, 2022 11:58 PM
jackra_1
Mar 8, 2016 02:56 PM
catbug12
Mar 6, 2016 11:21 AM
TMC21
Mar 5, 2016 07:58 PM
dogsoup
Mar 4, 2016 07:33 AM
