Replacement Cylinder Pistons
Old May 30, 2025 | 08:59 AM
ChristmasGT's Avatar
Question Replacement Cylinder Pistons
Hey everyone,
I'm trying to find replacement pistons for my engine block rebuild and wanted to get some guidance. At the moment, I have a new block with a set off pistons from a 2005 XKR. The original 2002 XJR 4.0L Piston is visually different from the 4.2L Piston in the 2005 Jaguar XKR
Currently, I've got the block sent off to the machine shop to be completely re-done and feel like this is a good time to replace the pistons as well due to mileage and age. Modern replacement information seems to be pretty scarce. While I've been able to track down the part numbers, sourcing new Pistons and Rods have been pretty problematic.
Are there any new potential replacements any longer?
2002 Jaguar XJR Style Piston:
2005 Jaguar XKR Style Piston (AJ811213):
Old May 30, 2025 | 09:45 AM
XJR-99's Avatar
Why not to use block and pistons from a 4.2 ?
Old May 30, 2025 | 11:20 AM
I'm actually going to be using the block from the 4.2 completely refreshed. But, wanted to see if there was any options for the pistons just due to them having unknown mileage.
Old May 30, 2025 | 11:44 AM
Quadcammer's Avatar
id see if you can get custom forged pistons made. JE, ROSS, CP are potential options, but it won't be cheap.
Old May 31, 2025 | 07:32 AM
XJR-99's Avatar
Maybe Pavel @ Pretuning can help you with CP-Carillos. Mine, oversized 4.2 style, are via him - but almost 10y ago.
https://pretuning.com/2013/06/2009-j...ngine-rebuild/ ( not my engine or car )
Old May 31, 2025 | 01:51 PM
Mjs128's Avatar
look here
https://www.jaguarforums.com/forum/x...-build-288467/
I had a set of forged rods and pistons made by a company called DP Engineering in Europe. I think I am a bit over 4k for the set which seems pretty good compared to other places I looked. I was the first to order so it was a new set for them so the lead time was damn near a year but I think they have turn them much faster now that the engineering is done. A work of caution, I have not built my engine yet so I cannot speak to the assembled quality but they look great in the box!
Kutthroat
Apr 20, 2023 06:55 AM
PierreW
25
Dec 22, 2021 10:18 PM
heuster
Jun 4, 2018 07:45 PM
P5EUDO
Aug 2, 2016 06:24 AM
thisguy
May 1, 2008 06:47 AM
