Replacement of exterior door handle
jag xjr 1999.. exterior left side door handle.. broken.. part i bought doesnot have the key lock feature as does my broken part.. if installed... would I be able to lock/unlock door using the remote? tks
Welcome to the forums dianap,
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
When you replace the door handle, you will see there is shield to avoid easily "slim jimming" the door handle. Remove the shield and at least someone will be able to break into you car without going through one of the windows, destructively.
FS[NorthWest]: '94 XJ6 left exterior door handle
Shaemus
Oct 10, 2013 10:41 AM
mhannaoui
Nov 22, 2012 01:45 PM
